Let's make a solar battery panel without soldering!
Put the solar battery cell #1 facing down on the solar panel in its position, and put one side of conductive tape on a positive terminal and the other side of the tape on the cell #1.
Turn the taped solar battery cell #1 over facing up.
Locate the solar battery cell #1 in the rimmed position.
Put one side of a piece of conductive tape on the solar battery cell #1.
Put one side of conductive tape on the solar battery #1 and the other side of the tape on the solar battery #2.
Put a piece of conductive tape on the solar battery cell #2.
Do the same thing with the next solar battery cell as done to the solar battery cell #1 and #2.
Put one side of the conductive tape on the solar battery cell #4 and the other side of the tape on a negative terminal on the panel.
Check whether the solar battery generates the power either from the solar light or from the incandescent light.
Observe the seed of the spinning motor driven propeller.
Observe the voltage of the solar battery indicates 2V
http://youtu.be/4TB9_xVxGeU
Fact: It will take you more than 10 years to pay back
Solution: Using Surplus Solar Cells You can get pay back in 1-2 years
There is an Engineer from Chicago his name is John Sommer
He explain it All in his diy solar panels Blog Search for him using Google
Type "top diy solar panels" Open the first Result.
Note: Ignore the adds at the top.
