Making a Steady Rest for Metal Lathe
2,195
35
Published
Introduction: Making a Steady Rest for Metal Lathe
About: Welcome to the Make it Extreme channel. Our channel aims to provide fun, inspiration and food for thought to our viewers by watching how structures are made in our workshop. Also, by making furniture, en...
The particular video was not only interesting but also it was necessary to be made as the tool that we created, this time, will provide us further help in the following structures. The tool that we created is a steady rest tool for our lathe. When we bought the lathe, we felt insufficient without having this tool so we decided to make one. It is very useful as it supports long pieces that we want to work on and it reduces the declination of being precise. Also, it prevents the thin pieces to be bend during the work on them and it provides many other benefits too.
Step 1: Start
We started making it by taking the measures of the lathe so that our component would be placed precisely and be able to be locked at the point we want. Therefore, we made its base, in which we placed two rings having 4cm distance between them. Separating these rings in 120 degrees in other words dividing them in three parts, we spotted the points to put the rails between the rings. These rails, on which the guided parts were placed, are moved forward and backward when we want to in order to be able to support pieces in various diameters.
Step 2: Finish
At the internal side of the movable parts, we placed a bearing so that the parts that we support to be able to spin smoothly. The only disadvantage that we have noticed on our structure is that we didn’t make it to open and close so that it can be only removed by removing the piece of the lathe. Closing, it is quite sufficient and a perfect tool for the purposes we need it, after all.
    • Casting Contest
      Casting Contest
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    Nice idea and I like that fact that you used bearings as the support rollers. That does cut down on the friction and allows replacement if any were needed. As far as the opening section, make a second prototype. There is nothing stopping you to do that and with each made, new ideas are incorporated. That is how so many things progress these days. You merely improve an older design. Good project though. that.
