You will need:
- Several lengths of wood. I used 2x4cm baton, and 5x5 cm for the base.
- Coat hangers.
- Some bolts and brackets (just what I had to hand)
- 8 large butt hinges with removable pins.
- 2 smaller hinges.
- 2 small pulleys.
- Some suitable thin cord.
- Black paint.
- 6m of Velcro.
- 8m of suitable material for a covering.
- A big bright light source.
- A blue revolving light.
- and a smoke machine...
Remove these ads by
Signing UpStep 1The Frame - part 1 - basic shape
The frame is made of wooden baton and hardboard corners for strength.
The hardest part of the frame is getting the geometry right. I used a cardboard model to work out just how big everything would be. (Unfortunately I don't have a picture of that). The process is to make panels out of card, and fit them together using a bit of tape so that you can see what the shape will be like in 3D. You can then measure the dimensions and angles. the dimensions you would scale to something approximating the size you want.
As an example: a piece of card for the door panel that measures 18cm, scaled 10 times would be 180cm, or 1.8 Meters.
Once you have worked out the lengths you can get your baton. In the UK we can get this from DIY shops in bundles of about 6 lengths each 2.4 meters long.
Lay the cut lengths out on the ground and MEASURE THOSE ANGLES. this is vital, as when you come to screw everything together, those angles need to be correct, or the whole thing will be wonky.
But does it have a chameleon circuit?
nice call i was wondering the same thing.
L
If you travel backwards in time the records will play backwards. And we all know where that leads...
Because if i travel back to lets say 500b.c., i dont think they got the right voltages there for me to come back.
