iImage Information
Pennannular brooches are common to many cultures. This particular style has been found in Viking silver hoards. I've seen Roman brooches of bronze. Convenient modern materials are copper (#6 wire, the size fastened to the pipes in your basement) and brass (3/32" brazing rod). You'll also need a hammer, a smooth block of metal, jewelers' pliers (preferably round-tipped), a file, and a gas flame. I'll illustrate using a propane torch, but I've also used gas kitchen stoves.
Use the pin to fasten a cloak at your right shoulder. This leaves your sword-arm free, just in case. Or take a square of cloth, a pin, and you have a shawl for those cold days.
Step 1The body of the brooch
iImage Information
Take a piece of #6 copper, 5-1/4" long. Polish it, then bend into a circle with the ends about 1/4" apart.
(but what if I turned the fabric???)
i will be making many.
av uh gud un.
Did you scan the illustrations, or create them in software?
(patington rocks too.)i have a race of sock-creatures that i call moozies",and mine uses tow of your pins. one to hold his cloak of webkin skins,(he HATES webkins.) and one to hold his sword(letter opener) belt. do you think steel would work?
It depends on what you call "steel". Certainly you could make cloak pins out of wrought iron or mild steel - I have a lovely elaborate pin by Magic Badger Smithies, worked up as a dragon. With higher carbon content steel, you would have to start hot working your pins, and maybe hardening and tempering them as well. (You can check out a how-to on similar steel-work at Jewelers' tools.) Different detail, but the hardening and tempering should work about the same.
Ellen
http://washuu.net/Cloak/Cloak-1.htm
Instructables is oriented towards pictures, with text. I'm more comfortable with text and illustrations. So it's easier for me to put old articles up on my own site.
And you're right about the blankets. Get a good stadium blanket, and you can be very comfortable at the games or walking down the November street.
click here
