Step 8Small pins and more
For a nice small pin, wind some of your 3/32" brass rod around a 5/8" rod to make a tight spiral. Cut off brooch bodies (like step 1, only smaller) so you have maybe a 3/16" open gap per body, then flatten then into a single plane. Use 1/16" brazing rod for the pins. Small ones can be worked cold.
I have also made these of sterling silver. It cold-works nicely when occasionally softened by heating in a flame then plunging into water. I've also done them in nickel silver, which behaves pretty much like brass.
(patington rocks too.)i have a race of sock-creatures that i call moozies",and mine uses tow of your pins. one to hold his cloak of webkin skins,(he HATES webkins.) and one to hold his sword(letter opener) belt. do you think steel would work?
It depends on what you call "steel". Certainly you could make cloak pins out of wrought iron or mild steel - I have a lovely elaborate pin by Magic Badger Smithies, worked up as a dragon. With higher carbon content steel, you would have to start hot working your pins, and maybe hardening and tempering them as well. (You can check out a how-to on similar steel-work at Jewelers' tools.) Different detail, but the hardening and tempering should work about the same.
Ellen
