Making a Wood Stove for Barbie Dollhouse (RGB LED + ATtiny 85)
1,658
16
Published
Introduction: Making a Wood Stove for Barbie Dollhouse (RGB LED + ATtiny 85)
About: Passionate of DIY of any kind, I am not of the trade (I am developer in computing) but I am self-taught and I like to learn new things. I decided to share my creations with you through photos and videos. I ...
Winter is approaching and Barbie cold, I propose the creation of a wood stove!
In modern appearance, it is made from a PVC tube drainage.
The fire is imitated with a RGB LED (3 colors) controlled by a ATtiny 85 (8-pin microcontroller programmed with Arduino Uno).
Vidéo :
https://youtu.be/kuuCpAYcWfs
(the subtitles are available in the video with translation)
Tools :
- Miter saw
- Drill
- Screwdriver
- Glue gun
- Soldering iron
- Hand tools (files, saw, screwdriver, cutter, pliers...)
Step 1: The Main Materials
I used a 50 mm PVC tube of water for the body, a bottle of Orangina for glass and PVC falls cut with hole saw, for the other parts.
Step 2: Electronics
Inspired by this article, I used an ATtiny85 and 8mm RGB LEDs to simulate a fire.
You can download the Arduino code and electronic scheme.
You can program the ATtiny85 with the Arduino uno board following this article or this article in french.
Step 3: Mounting
The stove is painted black with spray paint, the door is maintained with small hinges and I added a photo of fire in background.
Step 4: Finishes
The circuit is cut shorter and it is stuck with a the glue gun.
I added wood logs below.
I used an aluminum tube to the chimney.
Step 5: Done !
Once in place, Ken and Barbie can enjoy the fireplace comfort!
Find the construction of the dollhouse of Barbie here.
    • Planter Challenge
      Planter Challenge
    • Clocks Contest
      Clocks Contest
    2 Comments
    oooh j'avais pas vu passer celui-là! trop classe, Barbie est prête à affronter l'hiver :D
    Merci Riffifi, oui ça va chauffer chez Barbie ! ?
