I have now tested the yuloh with my boat and can report that I made a mistake with the choice of paddle material...a scrap piece of UPVC cladding. I chose it because it is easy to cut and will not rot, but hadn't bargained on it being so buoyant. The trouble is, it floats so well I was struggling to keep it under water!!!!!!!!! My next thought was to cut up a large polyethylene chopping board. This also floats having a relative density 0.93 or so, much greater than the UPVC and greater than Ash wood at 0.54 or Birch at 0.67. Looking at Bamboo itself, that is 0.3 to 0.4, so not a good choice either in terms of keeping it submerged.
Comments welcome.
Introduction (2nd Dec 2011)
I have a 3m long folding boat which you can row, sail, or use with an outboard motor. Rowing is OK but as you are facing backwards it is not that good for exploring...so I turned round and rowed forwards! Not as efficient maybe, but far more interesting and you are less likely to collide with something.
I made a sail out of some inexpensive tarpaulin using instructions from the Internet, and have since found that it would be useful to still have power and maneuverability even when the wind drops. The problem is that of having too few hands for managing the sail and two oars all together. Hence the idea of sculling with one oar like in a Venetian gondola, or a Chinese junk. It is also useful in narrow channels as two oars are unmanageable.
The oar has many names, 'Yuloh' being used in the Orient. It works like a slow propeller blade, reversing direction with each stroke. It has a curved handle, and this is a vital feature to enable easy sculling and good propulsion.
Here's a good idea of what it is and how it works:
http://www.youtube.com/watch?v=UjyE7dyR2X4
There are many photos on the Internet, but very few clear instructions on how to make one. This Instructable hopes to fill the gap for an inexpensive oar that can be made mostly from scrap.
The first problem to solve was what to use for the main 'pole' part, and how to get the curve. After some time the inspiration to use a thick bamboo pole emerged. However, firstly, I did not have one, and secondly it would be difficult to factor in the bend. I expect a green bamboo pole would be fine, but they are not available here. Undaunted, it occurred to me that by strapping six or so small diameter canes together I could achieve what I wanted.
The blade of the oar is made from a scrap piece of white UPVC cladding about 10mm thick.
Remove these ads by
Signing UpStep 1What you will need.
Black PVC waste pipe about 40mm internal diameter
40 or so 15cm cable ties
Metal band type worm screw-adjustable hose clip, 30-50mm diameter to clamp around the poles, but see photos for what I used.
Epoxy glue
Fibreglass tape.
4m polypropylene rope 10mm diameter
UPVC cladding off-cut for blade.
I also used these, but you could improvise to get the same effect. They are just used to get a good grip on the ends of the pole to bend it:-
1 waste-pipe 90 degree bend
1 waste-pipe T-connector
comments
Add Comment
Penolopy Bulnick
says:
Penolopy Bulnick
says:
Add Comment
