Introduction: Making a Brass Pocket Flask
I'am educating myself to be a proper wood chop teacher, have been working as it for four years and mostly need the degree to get a steady job and decent pay.
One of the many tasks we got was to make "a box with a lid" and i interpeted that as a pocket flask since i prefer to make thing that could be useful.
You need brass, lead-free tin, a 3/8" lid, a 3/8" sleeve, some paper, sheet metal cutter and soldering torch. The lid are the same kind thats used on radiators and plumming, easy to find and usually cheap.
Step 1: The Template
Start by making a template, think about how you want it to look. A made mine with a bit of airfoil shape, it hides nicely in the pocket.
Step 2: Cut the Metal
Use glue if you want to prevent the paper from moving. Make the top and bottom a bit larger, it should be ground down later. The top and bottom are the same shape so you only need to make one.
Polish the edges of the straight piece. In the next step it should be solderd.
Step 3: Soldering
Start by soldering the straight piece and the sleeve with silver solder.
If you use tin solder here it will part when you attaches the top and bottom.
When the soldering is ready you have to clean it. I used a light acid bath to cleance the metal.
Step 4: Tinning
Now we apply lead-free tin on the inside and if you want on the outside. The brass must be absolutely clean, use steel wool to clean if necessary.
Step 5: Assembly
When its tinned its time to assembly the flask. Solder the top and bottom pieces with tin solder.
Cut of the unnecessary brass with a metal scissor. Ground the edges to the right shape.
If you tin the outside you might get a nice effect by not soldering the ground areas.
Step 6: Polish
Polish the flask with steel wool until it's good enough to give to your father. Make sure to clean it properly inside.
Use it with care, alcohol is not healthy, it's illegal to carry it in some places and times.
21 Comments
what kind of cap did you use? i can't find any acceptable caps anywhere.
Sorry for late reply but maybe something like this?
http://www.ebay.com/itm/PLUMBING-FITTINGS-Brass-1-2-CAP-END-FEMALE-IRON-BRASSWEAR-BRAND-NEW-/250997485778?pt=UK_DIY_Materials_Plumbing_MJ&hash=item3a709db0d2
Do you remember specifics of any of the materials you used, like thickness of the sheet metal?
Are real hip flasks you can buy made this way? Soldered or welded?
Really Cool !! I like it !!
Why does it have to be tinned? Is it just to make it pretty or for a health reason?
From what i heard its because tin is one of the few non toxic metal, most other are a bit unhealthy.
maybe that is why the manufactured ones I have seen are made of Stainless. Nice project though, as much as I like scotch I would have to carry the bottle with me to keep the flask full. I have lots of silver solder though so maybe I will build a fifth flask ;) Thanks!
Thanks to all of you!
The degree includes both metal, wood and leather work byt is usually refered to as just Trä-slöjd / wood chop in Sweden.
Slojd is a bit hard to translate but the origin of the word is "sluug" to be handy and cunning.
It's a bit controversial to make pocket flask with 15-16 year old pupils but they usually love it and promise to wait until they are 18 to use it for strong alcohol...
If i get some spare time i'll upload some more works. This 'ible i did mostly to not have to do a powerpoint about the flask. ;-)
I was going to make a joke about High School kids making whiskey flask LOL. Might want to call it a water bottle (wink wink)
