http://www.chris-parry.co.uk
I also sell some items on http://www.chrisparry.etsy.com
If you are realy bored, you can visit my flickr page http://www.flickr.com/photos/chris-parry/
A client wanted a traditional design for his engagement ring.
This instructable shows you how his ring was created using the lost wax casting system.
To begin with I cut a section of jewellers wax, ( a special wax that has great properties for cutting, sawing and carving) into the basic ring shape. I created a hole the same size required for the finished ring.
Remove these ads by
Signing UpStep 1Seating the diamond.
I decided how high the diamond was to sit, then using small engraving tools, I cut a square hole for the diamond to sit in.
You can also make out lots of faint white lines on the wax ring blank. These will determine which partsof the wax are to be cut away to form the shape of the ring.
I'm including some photos with hopes that you might offer me any suggestions on the best way to set a round diamond into this configuration or point me to a resource vaguely like what I'm doing… I know, I'm a newbie… but this is a great learning experience!
I'm asking because I'm building a similar four prong semi square configuration to hold a round diamond. I have the measurements for the diamond so I'm building it just smaller than the diamond in order that someone (not me) can cut in the diamond and somehow fold over the prongs that have been cast into the ring. I do not want to use wax wire, I really want to "build" the prongs into the mold
**- HEY!! u didn't give a riser for the cast!! how does it work then? how u avoid blow holes or cast defects????
The process for casting precious metals is quite different compared to casting metals like iron, brass and aluminium. For one, you are often working with a much, much larger quantity, requiring risers to be employed.
My jeweler has made a wax model for the platinum ring that will be made. It is wide, at approx. 14.5mm at the top which tapers gradually to 8mm at the bottom (shank.) The finished ring will weigh approx. 26dwt.
He rounded the inside edge of the wax. Will this enable the ring to spin around on my finger compared to if he left the inside edge squared?
I have other rings with squared (not rounded) inside edges which do not spin on my finger, which is how I like it, and was wondering if a rounded edge would have the opposite effect.
Thank you for any guidance.
Can some one answer this question?
Thanks
you made a spelling error in step 9 "...again. tat however is for... "
i faved it
