A dust collector should be one of the first major purchases for any woodworking shop. Not only do they help keep things clean and tidy, they also protect your lungs from harmful airborne dust. A dust collector is only as good as it's filter, and as filters fill up with dust it reduces airflow and efficiency. One way to reduce this is to create a chip separating baffle, which collects most of the debris in a trash can before it reaches the filter. This instructable will show how I created a chip separator for my dust collector.
Remove these ads by
Signing UpStep 1: The dust collector
Being on a tight budget, I chose the 2hp model from Harbor Freight. I waited until it was on sale, and then used a 20% off coupon making the total price around $165 with tax. I think the 2hp rating is a little overly generous, but it still can't be beat for the money. The filter that comes with it only filters down to 5 microns, which means it won't collect the dust that is most harmful to your lungs. Rather than spend a bunch of money on an aftermarket filter, I decided to vent my system outside, eliminating the filter completely. I highly reccomend this approach if you're able to.
Visit Our Store »
Go Pro Today »
baffle. I like you design better, and I hate to just throw the center ring away and not use it. I'm going to vent to the outside through a dryer vent as well. I was wondering what the final "adjustment" to the inlet vs the slot was. Can you post a drawing of the exact position of the slot in conjunction with the inlet hose on the ring. Or email it to me?
That the blower was not designed to be operated in a vertical position. The shaft bearings may wear out quickly since they were not meant to support the load of the shaft pulling downward against the face of the bearing. I tried to find out about the bearings in mine but the manufacturer wouldn't answer my query.
Also the blower may possibly come loose and cause some damage or tear the housing apart since it also was not designed to be pointing downward. Gravity may help pull it loose or tear it all apart. Mine is only held on to the shaft by a setscrew, which is fine in the horizontal position. I'm not sure but I think that most vertically mounted blowers utilize a bolt and oversize washer threaded into the end of the shaft to hold it on.
I was also worried that the sheetmetal housing might not be strong enough to hold the weight of the motor without bowing in a little and changing the clearance between the blower and the front of the housing.
If yours is the same as mine (and it looks it), I would put it as far away from where I was working as I could. At the very least if it came apart right next to me, it would scare the devil out of me. There is a lot of kinetic energy going on there when it is at full speed and I'm not sure how much resistance a lightweight plastic barrel and a piece of plywood would offer in the way of containing it if it starts coming apart. If it starts sounding funny I would shut it off immediately. The Chinese products are not widely known for for being quality products and I didn't want to push my luck.
So....Is it still holding up now, 6 months later?
The impeller housing is more than strong enough to support the motor, and even if it bowed slightly, there is a disturbing amount of clearance beteen the blades and the housing. I almost wish it would bow a little so that efficiency would improve a little.
Since writing this 'ible, I've run PVC ducting to most of my tools, and made a bunch of blast gates. I've also rigged the assembly to lift off the barrel with a ratcheting hand winch and some pulleys, which makes emptying the barrel much easier. I also permanently secured the exhaust to something similar to a dryer vent.
www.billpentz.com/images/ClearVuelogo3.jpg This link is a pic of anothers attempt at just such a filter for your purpose.
Still, Kudos on the re-purposing design and "MacGyverism"
