loading
Step 7: Finishing your door.
On the front have given it a final sand to remove fingerprints and any original varnish from the wood,  then given it generous coats of a pine nut oil.
For the rear have given it 2 coats of high temp black paint.
Now leave it to dry over night and then get cooking!
Thanks for viewing my instructable,  constructive criticism welcomed : )
galvanized metal around fire is deadly maybe an aluminium strip or just blackmetal strapping is what I would look for instead of trying for Zinc poisonoing
if you build a fire(HOT HOT FIRE) and &quot;cook&quot; the galvanized steel in the fire, you will burn off any galvanized coating(after about 1 - 2 hours) and then it will be safe to use around food. <br><br>Experience has taught me this...I used to work in a foundry.
Hi, thanks for that, good to know... it's not a cooking surface and not in place when cooking so i was not worried.<br>Burning the galve in the fire like you are saying would make it rust really quick would it not?
use aluminium instead<br>
when heating or burning off galvanizeed metal it releases zinc oxide gas which can poison and/or kill you
Full marks for recycling, and a very nice looking project. This may seem unkind and I don't intend to pick holes, it's turned into a bit of a long post so please read all of it before becoming too unhappy. You have produced a very elegant looking door for your oven, and I'm really glad you chose to share this project. Can you point us to more details of the oven construction and use?<br><br>As I understand the operation of this kind of oven you &quot;fire&quot; it, get it all nice and hot and then clean out the fire and use the residual heat in the structure to cook the food. In a traditional oven, the door is SEALED with dough, clay, or any other convenient method, the idea being to retain the heat in the chamber for as long as possible. The ART of this kind of cooking lies in knowing when to break the seal, and how to schedule your cooking. Large loaves in the first batch, rolls or smaller loaves might be possible in a second batch, and if you're really good you might even manage pastries, in a final load as the oven cools.<br><br>In your case I suspect a hole in the door would prevent your oven from retaining heat effectively. The insulation IS an EXCELLENT plan and getting it out of an old storage heater is a good idea too, but are you using your oven with a fire inside AS YOU COOK?<br><br>
Hi, great questions, you probably know more than me about this subject reading that comment : )<br><br>Yes this is my firing door, i will build another exact replica but with a second recess protruding further into the oven making it around 100-120mm overall thickness... this door will be for baking with no breathing holes.<br>The baking door will be for heat retention for long periods, i will also be using a flue damper to stop that rising heat escaping.<br><br>This door will be used when firing and between cooking pizzas, BBQ food etc yes while the coals are still inside.<br>Also will most likely add a damper to the front of this door to control air flow as i am building a smoking chamber above my oven, will update when i have done this.<br><br>With this firing door, it will heat the oven much faster than without a door, its best to burn the oven for a bit to preheat so it does not suffer from thermal shock but once you put the door in place its like someone blowing on the fire... it really cranks it!<br><br>If this rain ever stops i will shoot a short video to show how it works.<br>Please view my other projects for the oven construction... still not finished yet... hope to get it done after xmas.<br><br>Cheers for your questions
About This Instructable
54,337views
112favorites
License:
Bio: Self employed Stonemason.
More by howgoodisit:Home Brew Beer Crates from pallets! Wood fired oven kit installation... XL version! Making a insulated wood fired oven door.
Add instructable to:
