Making a Lighted Kindle (Fourth Generation) Case
Introduction: Making a Lighted Kindle (Fourth Generation) Case
The official kindle touch (kindle fourth generation) lighted case runs 60 dollars, doesn't light the kindle very effectively, and apparently is prone to breaking.  So rather than drop $60 dollars for a $100 device.  But using a small reading light eats up batteries and isn't very environmentally friendly, so we're going to make our own lighted case that runs of the internal rechargeable kindle battery for about $15.  One of my main goals with this project was to make sure that the kindle could easily be inserted and removed from the case and not have a ton of wires hanging off the back of the kindle when you do so.
Step 1: Gather the Materials
To do this project I used the following items:
A kindle case - I bought a $10 one from best buy
A battery powered reading light that you don't mind using up
Metal bars -  To get power from the contact pad of the kindle (I used a pair of battery bars, got them off eBay or Amazon for $5)
Short length of wire - To connect the light to the metal bars
Solder/Soldering iron
Hot glue/hot glue gun
330-Ohm 1/2 watt, 5% tolerance resistor from radio shack - optional to reduce brightness of light ($1.19)
Step 2: Make the Pads Useable
When I was working on this project one problem I ran into was making a firm contact with the two contact pads on the back of the kindle.  Turns out the issue is that the pads are recessed.  I tried to take my metal bars and put a bump on them to contact the pads, but getting the right size bump in the right spot proved too big a hassle to be worth while.
My final solution was to take my soldering iron, put just a bit of excess solder on the tip of the iron, a bit of flux on the pads, and after a second or two of touching the iron to the pads left just enough of a bump on the pads to make them useful.
For reference, when the back is showing the pad on the left is the positive terminal and the pad of the right is the negative terminal (this mean when the kindle is face up the positive terminal will be the one on the right and the negative will be on the left)
Step 3: Prepare the Light
Before I messed with the case, I measured how much wire I would need to provide power for the light.  Once I had that I cut my wire and drilled a hole through the light into the battery compartment.
One tip I would give on this that if you're buying a light just for this, try and get one that has it's battery compartment on the back side rather than between the light and clip.  Mine had the battery compartment in this middle like this and I had to drill an additional hole through the clip so it would shut and turn the light off!
Once the wire is through attach them to the appropriate terminal.  I would suggest doing this temporarily as after I had finished the project, I found that the light was getting too much power which would have shortened the lifespan of the LED, but more importantly annoyed my wife defeating the purpose of having a tiny reading light for my kindle in the first place!
The kindle touch provides ~5V @ 55mA through it's contact pads (or at least that's what my voltmeter said) I decided I want to lower this down to around ~10mA, it would dim the led and lengthen its life span back to normal.  So to drop it from 55mA to 10mA I decided I needed a 330-ohm resistor... this might have been bad math :-P  I'm no electrical engineer, but it brought the light down to the level I wanted to I count it as a victory!
Once you're satisfied with the level of light being outputted, solder the wires in place.  I put a bit of electrical tap around the resistor to make sure there was no accidental contact with the positive terminal before the resistor.
In the photo below the reason it looks so messy is because I used some flux on the pads when I soldered it, but I didn't bother cleaning it up too much since it's hidden away and doesn't need to look nice.
Step 4: Prepare the Case
First if your bars are like mine, then they have a minus on one side and a plus on the other (they are designed to solder two batteries together).   I used the "plus side" to solder my wires to and the "minus side" to connect with the kindle's contact pads.  I put just a little bit of solder on the minus side to cover up the minus and create a bit of a bump to ensure a good solid contact with the kindle.
Also make sure to solder the wires to the metal bars before affixing them to the case as this is far easier than trying to solder them on *after* they're already in place on the case.
Measure out the distance from where your kindle will sit in the case to where you need to place the pads.  Once you know where they need to be use the hot glue to affix the metal bar onto the case.  Now I chose hot glue since I was dealing with a cloth case, but if you're using a different material be sure that hot glue will actually stick to it!  If you have more skill than I do, you might want to consider trying to use some conductive cloth rather than the metal bars and wires as that would look more attractive.
Once the bars are in place, it's time to test it out!  Place your kindle in the case and power it on (the kindle does not output power through it's terminals when it is in standby mode).  If it doesn't work, check your connections and the placement of your bars.  It took me a couple tries to get it just right.
Step 5: Congratulations!
You now have your own lighted kindle case that runs off the kindle's battery for a sixth of the cost!  You can see the photos that show the light turned on, and it all shut up and tucked out of the way for whenever I don't need it!
    • Science of Cooking
      Science of Cooking
    • Trash to Treasure
      Trash to Treasure
    • Paper Contest 2018
      Paper Contest 2018
    Just wanted to say THANK YOU for a great instructable - it's a godsend! I have looked everywhere and couldn't find any lighting solution that I liked (who wants to carry around a silly extra attachment!). I have a Kobo, but the principle is the same. Will be attempting this tomorrow.
    I also have a Kindle Touch. My wife gave me an LED light powered by its own AAA battery. It has a flexible head, and a touch switch with three different levels of light intensity. I use it some, but not a great deal, although it is good for reading at night in a car while someone else is driving.
    I expect you must carry your light with you as long as your Kindle is in its case. The wiring is fastened to the case.
    I also have the English Standard Version of the Bible on my Kindle, and I have the Holman Christian Study Bible on it, too. Both are free in the Kindle Store.
    Thank you for your Instructable.
    Yep, the light is permanently attached to the case. I had though about trying to make it removable, but I didn't like any of the solutions I thought of (mainly because they made the project much more expensive). I did make sure to have enough wire such that I can clip the light on in an out of the place location whenever I'm not using it whether the case is opened or closed.
