3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Making a simple laminate longbow
This is a short guide on how to make a VERY simple laminate longbow. If at the end of this tutorial, you have any questions that are not answered, or you would like more detailed instructions on how to make a longbow, check out www.makingtraditionalbows.com
Step 1
Step 1
Cut the laminates using a circular saw or a band saw. The dimensions of the belly laminate should be about 75" by 1 1/2" by 1", and the dimensions of the back laminate 75" by 1 1/2" by 3/16". The grain of the back laminate must run straight down the length of the board and be uncut.
When shooting a bow the belly side is towards you and the back is facing away.
Optional belly woods: Yew, osage, lemonwood, ipe, oak and more.
Woods for backing: Hickory, ash and more.
38 comments
May 27, 2012. 11:34 PMjmichelin says:
I eas wondeing how to make a bow out of thinner materials, and i was wondering how thick all you guys make your bows, a laminated english war bow would be neat
Nov 14, 2011. 9:53 AMmvankan says:
I think you are missing a few steps.... to make a good longbow anyways.....
Apr 2, 2012. 6:07 PMfatchumba667 says:
Just remember this is an 'ible of a SIMPLE laminate longbow, made easy for people probably who want a neat project for a sunday afternoon or simply learning bow making :)
Nov 16, 2011. 3:04 PMa4great says:
I agree... It would have been nice if he also showed stringing (was a tad confusing).
Dec 4, 2011. 4:23 PMRteen says:
I had some trouble finding that out too
Dec 7, 2011. 1:36 AMnerd12 says:
easy way to string most bows-
1. hold bow as normal and place lower end in ground
2. attach the slipknot of the string to the lower end
3. grasp the other end of the string and bend the bow down.
4. loop the knot over end.
5. check both ends for tightness (to see if the string is slipping or might when firing
Thats about it!
have fun and play safe
Dec 21, 2011. 8:13 PMPENNY1999 says:
where did you get those woods and how far does it shoot? and by the way YOU ARE AWESOME!!!!!!!!!
Dec 16, 2011. 10:49 AMedvannatta68 says:
see this cool want long mach this
Nov 24, 2011. 6:32 PMthomas 666 says:
what wood did you use to make it ?
Nov 12, 2011. 12:07 AMhighjacked says:
What's the draw strength on this bow?
Nov 13, 2011. 2:18 PMscorpman says:
longbows do not have a set draw length like a compound bow. You pull it back to the length you need. The father you pull it back, the harder it get.
Nov 13, 2011. 10:08 PMMrjamfunkalot says:
Actually there is a draw weight to longbows. The draw length on average runs about 28" and the weight is measured by placing the bow on a suspended scale and pulling down to that distance. Based on the thickness and number of your tapered laminates including the length of your bow there will be variations to this weight. Material also plays a roll. Indeed there are different drawing distances based on who is pulling it back but the draw weight is measurable.
Nov 13, 2011. 12:12 PMLord Jon Bigglesworth says:
Longbows were originally drawn back to the ear or farther, while most other bows were pulled back to the eyes. Longbowmen required 10 years of training in order to build up the muscle in their drawing arm. A typical longbowman could fire 12-15 shots in a minute, with very high accuracy. In this way, they were actually more effective than the muskets which were coming into use. However, you didn't need 10 years to train a person to shoot a gun, so longbows were used only in England, and only for a very short window of time (around a century, if memory serves).
In any case, there is no measure of how much power the bow has per say, unless you know exactly how far back you draw it every time, and you know the equations based on your bow, the type of wood, the string, your draw length, etc.
Nov 14, 2011. 4:50 PMcblackwell says:
Also, native american style bows were usually shot "instinctively", which is a different style. The bow arm is pushed forward while the arrow hand is pulled back to the area of the chin or corner of the mouth. One fluid movement and then released when 'instinct' said it was on target. The bow was not held in the pulled position for more than a second.
The hold position seems to come from a military background where archers worked in groups rather than a hunting style where they worked alone. For most native traditions the range was much closer than modern hunters would believe. 3 to 10 feet being the range for a honorable kill of the animal. "the arrow would enter the animal before the fletching/feathers passed the hand." It takes good stalking or hiding/camouflage/scent masking skills compared to a tree stand shot at 50 feet. A different skill set for a different time and tradition.
Nov 13, 2011. 11:04 PMDaiVrath says:
One small correction: Longbowmen used back muscles just as much as arm muscles, both are required to use such powerful bows.
Other than that everything you said was right on.
Nov 13, 2011. 2:12 PMperiodthree says:
Where do you buy your timber?
Nov 11, 2011. 8:08 AMAaronius says:
Simple, effective and beautiful. Can red or white oak be used?
Nov 14, 2011. 10:45 PMelectrowizard says:
Yes,white oak can and is used,as for red oak,it is less common,you could use it for a backing.
Nov 13, 2011. 5:51 PMstar_dust says:
Belly side? Belly tapers? Please explain.
Nov 14, 2011. 4:41 PMcblackwell says:
Think of holding the bow as dancing with your partner. The belly is towards you and the back is away.
Belly tapers are usually the fade from the thicker, unbending handle to the bending/working parts of the bow. Smooth and graceful to avoid a hinge type fracture of the wood.
Nov 13, 2011. 9:20 PMSun Spirit says:
Another way to describe the belly is the side of the bow closest the one sees as one shoots, easy to remember because it's the side closest to the one's belly.
Nov 13, 2011. 12:04 PMLord Jon Bigglesworth says:
The belly is the inside of the bow, where you would put your hand. What he means is, taper only that side, not the outside.
Nov 14, 2011. 11:11 AMilpug says:
Oak and willow work, but are less springy in general, and are more susceptible to humidity.
Nov 14, 2011. 1:03 AMnerd12 says:
i actually tried this method but due to a distinct lack of good wood i used ply wood. worst mistake ever. certainly not even mildly springy enough for a bow. i laminated two pieces together and then bent it while gluing to hold its shape. i wanted to make a re-curve bow but it was so inflexible and strong that now i use it as a practice katana
Nov 13, 2011. 11:01 PMcricket3_2000 says:
Can you get this type of wood and glue at lowes? About how much does it cost to make one?
Nov 13, 2011. 10:23 AMmrmucox says:
It is very important to use good glue! I have had my bow, which I spent many hours shaping and working on, break the second time I tried it out because the backing de-laminated. The friend who taught me, has also had this happen a few times. Elmer's wood glue is NOT a good choice. take a look at some of the traditional archery websites for the best glue choices.
Nov 13, 2011. 6:29 PMSpeidumb says:
TItebond III works well, and it is designed for outdoor use. If you really want to do it professional style, use URAC 185. It is the glue that professionals use when they make bows - a quick look on ebay shows 1 pint for about $20 including shipping.
Nov 13, 2011. 10:15 PMMrjamfunkalot says:
There is also an epoxy called smooth-on which is a flexible laminating epoxy and it is sold by a company called Bingham Inc. they are a bow making supplier of materials. They also sell laminates and patterns to custom build a bow press for longbows and recurves including take down bows. They even sell strips of carbon fiber to run in the core of the bow for added performance.
Nov 13, 2011. 6:31 AMabakels says:
Use by shooting with a bow a bandage on your arm for protect to become injured.
Nov 11, 2011. 10:32 AMthepelton says:
The prescribed woods are there because of their natural springiness, not their looks. Oak doesn't have the springiness of yew or osage orange. English laburnum would also work.
Nov 11, 2011. 10:26 AMscoochmaroo says:
Gorgeous! I want one.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
17
Author:ChrisMBows(www.makingtraditionalbows.com)
