Introduction: Making a Tassel
This is a guide to making a simple tassel.
You will need
2 different colours of thread
Small crochet hook
metal jewelry jump ring
sizzors
Step 1: Cut the Thread
Cut the main thread into lengths 8 times longer than you plan to have your tassel.
Fold each thread twice (so it is 4 threads wide)
Step 2: Thread Through Jump Ring
Pull the thread through the jump ring and fold over.
repeat until no more thread can fit through ring.
The crochet hook is useful for the last few strings.
Step 3: Secure
Tie the second colour string around the tassel, just under the ring. Make sure it is a reasnoble length (about 30cm is good)
Tie it as tight as possible (single knot).
Step 4: Tidy Up
Pull on each of the strings so they are tight over the jump ring and even.
Then take the red string and wrap tightly around the tassel a couple of times and tie off.
Step 5: Add the Loop
Push the crochet hook through the center of the jump ring.
Catch one of the red strings (about half way down its length).
Pull the string through the center of the tassel (careful not to pull it all through)
Step 6: Tie the Red String
Tie the two ends of the red string together in the center of the tassel (so knot is hidden from view).
Step 7: Tidy Up
Cut all the strings at the end and make sure they are reasonably even.
Done.
This instructable was brought to you by:
Dharmashine (etsy shop selling beading supplies and mala's)
http://www.etsy.com/shop/DharmaShine
