Making an Air Cannon / Potato Cannon
video Making an Air Cannon / Potato Cannon
Here I build a pair of air cannons - one large, one small-er. More information on the build and sweet HD video of it in action at http://www.crazybuilders.com/item.php?id=000004&type=project_section
7 comments
Jan 24, 2009. 2:52 PMphotis22 says:
Could this cannon be converted to combustion easily if you added an ignition source?
Jan 19, 2009. 12:05 PMaseaheru says:
please add instructions for both, also item lists.... projectiles?
Jan 15, 2009. 9:54 PMThe Porsche Fan says:
that was pretty cool, where's the video of firing it, and how much did it cost to make (small one)
Dec 22, 2008. 7:08 AMrock climber says:
Nice cannon. Does it leak at all?
Nov 22, 2008. 1:05 PMxandardrax says:
I like your design and your video is well done with the split screen. One thing you might want to consider is using air power with pipe thread tape sometimes causes rusting of the joints and tape failure. This can be prevented by using a pipe thread compound. I used to install high pressure air systems as part of my job and would recommend Loctite Thread Sealant. If you let your system sit pressurized for too long water condensation with introduce the rust to the system. Although depending on how you pressurize the system you may not have moisture problems.
Nov 22, 2008. 3:53 PMxandardrax says:
just trying to be helpful...that is what this site is all about. People coming together to help each other learn and explore.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
29
Author:crazybuilders
Hey, my name is Ryan Bavetta and I live in Boston, MA. I work on a website: http://www.crazybuilders.com Follow me on twitter: @ryanbavetta
