Introduction: Making an ElectroMagnet
Picture of Making an ElectroMagnet
Overview: Our goal here is to make a simple electromagnet that can pick up objects made of iron or steel, without using a magnet.
Materials: a long metal bolt, a roll of insulated copper wire, three battery holders, and five alligator clips, a pair of scissors, 9 AA batteries, and small iron objects.
Step 1: Wrapping the Wire.
Picture of Wrapping the Wire.
1. Wrap the bolt with the copper wire by coiling around it with the loops as close as possible, the more loops you add, the greater the magnetic force generated by the circuit.
Step 2: Hooking Up the Circuit.
Picture of Hooking Up the Circuit.
2. daisy chain the wrapped bolt and three battery packs using alligator clips, in a circuit as shown above.
Step 3: Using Your Magnet.
Picture of Using Your Magnet.
3. Try out your magnet by holding the wrapped bolt nearby iron objects, see if it picks up them, if it does, then congratulations, you've got a working magnet!
Step 4: TEST RESULTS
If successfully connected, as shown here, you can pick up many different iron objects as well as attracting and repelling other magnets as well. Just hold your magnet near the object, and it will either stick or be pushed away.
Step 5: Explanation.
Picture of Explanation.
The bolt becomes magnetic once a current is applied to the coil wrapped around it because electric currents produce magnetic fields. If the wire is wrapped around a coil, the magnetic fields will be concentrated in the loops, which is strengthened when its wrapped around a core, normally the atoms in iron or steel are pointing random directions, but when a current is applied to them, they line up pointing in one direction, and their magnetic fields will add up to create a larger magnetic field that attracts objects, eventually if you give it enough time, the bolt will become permanently magnetized and changing the electric current won't affect it anymore.
muhammajunaid (author)2016-06-16
I want to make a mechanism like that of a door bell where electro magnet is engaged and disengaged many times to create the ringing bell. but I want a stronger mechanism. can someone please guide me on how the thickness of wire and numbers of turns effects the strength of the magnets.
ндогонят (author)2015-01-08
Unfortunately, this is a bit too short.
A nice thing would be to explain how voltage (in volts V) and intensity (in amperes A) make the power of the magnet (in teslas) vary, how you can have multiple electro-magnets interact together, the importance of wiring direction on polarity, etc.
I have a project in mind involving electro-magnets, I fear I'll have to check all this by experimentation...
Thank you for the 101.
You have details on those VOLT's, Tesla's, AMP's and at I also wonder how to know till which max my wire could go...?
I also want do a project based on electro magnet's.
billbucket (author)2015-01-08
You should check the resistance of your battery packs and that of your wire. It may be that connecting the packs in parallel, rather than series, will provide more current and increase the strength of your electromagnet.
seamster (author)2015-01-08
Excellent project! Very nicely done, I'm going to have to make an electromagnet with my kids. Thank you!
About This Instructable
9,497views
244favorites
License:
More by smartguest:Making an ElectroMagnet
Add instructable to:
