3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Making an army of Gromit's (Claymation Mold making)
Step 2Give 'em some bones!
Give \
Using your drawing as a guide you need to measure and cut the lengths of wire for the armature (skeleton). You need to double up the lengths as you will be twisting the wire together to make it stronger and more flexible.
You will end up with 5 pieces of wire (2 arms, 2 legs, a torso), Assuming you are making a humanoid.
Each piece of wire will be double the length of the body part it represents. For the head leave a big loop in the torso wire, and put loops for the hands and feet.
After you have cut the wire to the right lengths and use the drill and pliers to twist them together.
Use the Sculpey to block out the chest, pelvis, hands and feet of the skeleton, and to hold the wire together. When you are done put the armature on a baking sheet and bake the Sculpey permanently hard in your home oven, 15-20 minutes at 275ºF. Remove and leave to cool.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
37
Author:edwatkins
