Before I get started on the actual project I should thank Mark Spagnolo, whose video podcast The Wood Whisperer inspired me to do this project. Mark has a great video (Episode 7: A Cut Above) which breaks down the process well. Still, I thought I would show my step-by-step process for anyone interested, including some of the different designs I made. I also include some of the mistakes I made along the way which might trip up fellow beginners.
I am still new to both making cutting boards and woodworking in general, so if anyone has constructive criticism or suggestions, please share them in the comments.
Update: Workshop
If you are a member of Techshop in the San Francisco area, I teach a monthly workshop on making these cutting boards at Techshop SOMA. Students work on steps 1-7 in the workshop, then I demonstrate later steps with my own materials. Link to workshop page
Remove these ads by
Signing UpStep 1: Tools and materials
Tools used
- Table saw
- Compound miter saw
- Power jointer
- Power planer
- Table router
- Pipe clamps
- C-clamps OR F-clamps
- Ink-roller / Brayer (for applying glue)
- Duct tape OR packing tape
- Small scrap lumber
- Paper towels or clean rags
- Power sander and/or sandpaper
- Pencil
- Tape measurer
- Combination square
- Calipers
Materials (cost ~$25 - $30 per cutting board)
I used rough cut lumber because I have access to jointer and planer machines, and it's a lot cheaper than pre-milled (aka S4S) lumber. If you don't have access to milling tools, most hardwood suppliers will have pre-milled lumber for you to use. My local shop - MacBeath Hardwood, even has cutting board kits with pre-milled and pre-cut strips ready to glue.- Hardwood - Rough cut maple, cherry and walnut* - 1.5" thick (aka 6/4 thick)
- Wood glue - Titebond III (FDA approved for food contact)
- Finish option 1: Varnish - Emmet's Good Stuff (FDA approved food safe)
- Finish option 2: Mineral oil and natural wax (beeswax and carnuba wax are popular)
Software (Free)
- CBDesigner - A great (free!) program for designing cutting boards, discussed more later
Visit Our Store »
Go Pro Today »
As you said, it took me about 10 minutes to accomplish what took an hour or more with the sander. I won't waste my time with the other methods anymore - unless a drum sander happens to fall in my lap. The plane I used was a standard angle, though I could see how a low angle plane could make the work even easier.
This will definitely change my woodworking. I think the first time I tried using a hand plane it must have been dull and / or poorly adjusted - so I just figured it wasn't the right tool for the job. I'm glad I was wrong.
It's sad that the power tool manufacturers have convinced us that we need power to do woodworking (I would, too, if I was selling power tools). The opposite is true - hanad tools are faster, more accurate, and produce a finer finish than ppowwer tools can. Think of the power tools as yoour "coarse" tools, doing the bulk rough work to get near your final dimensions, then use your hand tools as "fine" tools - tweaking the dimensions within thousandths of an inch (if you need that accuracy) and leaving an unparalleled fine finish.
I know your handle is WorkIsLove, but with hand tools, you can change it to LessWorkIsMoreLoveAndAPerfectFinish. Please look at the vendors I mentioned, buy a low-angle plane, throw away your sander and the endless costly pads, belts, etc., and have fun working wood.
Truly, thank you for your constructive criticism. Comments like this help both me and the instructable improve. I will update it as I learn more.
Or perhaps I'll invest in my own. But right now I don't have the money to go buying tools without knowing what to look for. Early on I walked into a Woodcraft store, but the selection was so large and confusing, I had no idea what to get. Shopping online is even worse - everyone has opinions and advice, and they are all different. I plan to get a few projects under my belt before I go buying my own tools. After I know what type of woodworking I generally want to do, then I'll know what to ask for when I go shopping.
Nice Instructable - stay safe!
