loading
Step 3: Designing the Board
Pattern
The first three boards pictured are classic cutting board designs using stripes and checkers. they were designed using a great (free!) program called CB Designer, written by a gracious woodworker. UPDATE - Another woodworker that took my San Francisco based cutting board workshop wrote a browser-based version of CB Designer - which is also capable of managing some angled cuts to make zig-zags and chevron designs.
If you play with the settings on either CB Designer, you can also create slightly more complex designs - for example in the final picture I created a staggered pattern by changing the width of just one strip of maple from 1 inch to 1/2 inch. In addition to helping you plan a pattern CB Designer helps plan what length to cut the wood, how many cuts you need to make, and how much wood will be used up in the cutting process.
If you follow the link, the creator has a video showing how to use the program.
Freestyle Design
In the last cutting board pictured, instead of using CB Designer, I used some scrap pieces of wood to make something more creative than normal stripes or checkers. CB Designer can't handle this type of pattern, but it's easy to think up your own design. I took some scraps of bevel-cut wood from other projects and thought about different ways I could arrange the pieces into interesting patterns. The possibilities are endless, I have seen other's create diamond patterns, flowers, and waves - just remember to think about your design from the perspective of end grain. I sketched out my ideas on google docs, brainstorming 4 different possible patterns using the end-grain profile of my scrap pieces.
Even though CB designer can't show these freestyle patterns, you can still use it to calculate the length of your wood pieces and the amount of wood waste.
Lumber choice
Cutting boards can be made out of any wood, though some woods are better than others. The important thing is that it is a hardwood, with dense fibers, small pores, and no toxic oil / sap / chemicals. Hard maple (aka rock maple) is the classic choice - other common woods include cherry, walnut, purple heart, and yellow-heart.
Many other woods will work, but it's a good idea to do some research before choosing exotic woods, which may not be food safe. Some woods contain a lot of natural oils, which can be toxic or cause problems for people with allergies. Other woods, while food-safe, may not be the best choice because of their grain structure - soft-woods and open-pore woods such as oak or ash may allow more liquid to soak into their fibers, giving bacteria a place to grow.
If using rough-cut lumber, like me, make sure to look at the condition of the wood. Cutting boards are constantly exposed to liquid and moisture - rough cut wood that is already warping at the lumberyard may be much more prone to warping in your kitchen - look for straight boards.
Also, pay more attention to the end-grain pattern of the lumber instead of the face grain pattern. Knots or figure that may look interesting on the face of a board will not be visible in the finished board, because only the end grain will be showing. Knots or heavy wood figure may even be hiding empty spaces in the center of the board that will show up as a hole in your cutting board once you cross-cut and expose the end-grain.
Thickness
Anything from 1-2 inches is common for a cutting board. Make it even thicker to create an old-school butcher block or whole end-grain countertop. In general thicker boards will be more stable while cutting, are less prone to warping from moisture, and can take more re-finishings after heavy use.
Remember that the thickness of your cutting board is not directly determined by the thickness of your lumber. When making an end-grain cutting board you get to determine the thickness of your board based on the cuts you make (step 9). The thickness of the lumber just determines the width of the individual strips on your board.
It's important to determine the thickness of your board before you cut any wood. When making my first board I used CB Designer to make a 1.5" thick board, but at the last minute changed my mind and made a 2" thick board - this 1/2 inch difference had a big effect when multiplied by 11 cuts. The end result was still nice, but much shorter than originally planned (First example pictured).
<p><a href="https://www.instructables.com/member/workislove" rel="nofollow">workislove</a> I see this 'ible is about 4 years old now (8/9/2016). I've been making end-grain boards for just about that same 4 year time frame. This is, by far, one of the best instruction sheets I've ever seen. You took great pains to include everything you could think of to help a fellow woodworker do this job. Kudos to you, sir. Keep up the good work. And I must say your boards look GREAT. Thanks again.</p>
<p>I recommend against using any varnish on any cutting board. Instead, use a non hardening oil like mineral oil. This allows you to add more oils, as needed without sanding the old surface, or removing it. <br><br>Non-hardening oils penetrate and work well at stopping the wood from drying, which results in splitting and cracking. <br><br>Don't use olive oil. It goes rancid and you will smell it and can taste it in the quantities you'd use for treating the wood.</p><p>My practice is to slather the oil on and let it soak in. Then, where it soaks in, slather on more. The oil will penetrate and could, eventually, saturate the wood. As suggested, saturated wood is not going to dry and split or separate.</p><p>You don't need fancy oils. Just stop in at a Walmart or some place selling bottles for around a buck and a half a bottle.<br><br>If varnish fails, the wood can still dry. To add a new coat, you have to </p>
<p>I personally recommend oil in most cases as well, but when I made this 'ible I decided to try both on two different board and perform a long term test. My poly board stayed clean and intact for 3+ years so far, so far poly worked fine for me in the medium term. However, it was easy to over-finish with poly and one side of the board showed a lot more scratches than the oiled one.</p><p>That said, a lot of people also end up making fancy cutting boards as seldom-used or purely decorative items, in which case varnish is entirely appropriate. How many times I've heard &quot;but it's too nice to actually use!&quot; from people buying or recieving these boards.</p>
<p>After a while, your untreated butcher block can dry, which will cause cracks, splits and separations. Saturating the wood with non-hardening oil will swell it and make most of those defects dissappear.</p>
<p>I included a section on fiinishing the board and recommended mineral oil, sorry if you didn't see it.</p>
<p>This is not only an amazing instructable, but Seth is also a wonderful, thorough, and inspiring teacher in person. I highly recommend taking his class at Techshop San Francisco where you get to make this exact cutting board! I loved his class. Thanks for raising the bar on what an instructable can convey!</p>
<p>I REALLY enjoyed this instructable and am now trying my hand with making an end-grain cutting board!! I especially appreciated your comparison between varnish and mineral oil with wax. I wonder if you have any updates on how well your two boards have held up over time - which finish you would use now. Thanks!</p>
<p>I'm glad it helped you! Both boards have held up just fine. I slacked off on the mineral oil board a couple times and that one started to hold some strong odors like garlic - but a good scrub and generous oil / waxing brought it back.</p><p>Both boards are clearly quite used, but I'd say the oiled board looks a bit better - the scratches on the varnished board just stand out more. I now make these boards to sell, and I use oil/wax by default, but offer varnish as an option on custom boards.</p>
very nice i have been wanting a new telecaster but cant afford a body blank but using a cutting board like this one i could build<a href="http://www.zacharyguitars.com/070209pics.htm" rel="nofollow"> this</a>
I am so excited. I just signed up for this workshop!!
Awesome! I'll see you there :^D
You have not considered the time-tested method for flattening these - a HAND PLANE. Power tools are wonderful, but not always the best method. Sanders (especially belt sanders) can leave grooves and uneven surfaces; a router for leveling the surface seems like over-kill. Also, end grain is notoriously tough (that's why you made a cutting board using end grain!) - sanding it takes forever, and risks making it uneven. Try a sharp hand plane, but you need one with the blade set at a low-angle for end grain, not the standard 45 degree plane blade angle used on face grain and side grain. The low-angle planes are called &quot;block planes&quot; - guess why? - they've been used for centuries for surfacing end grain butcher blocks and cutting boards, or any other end-grain cuts that a woodworker has to plane flat. Don't be afraid of hand tools!!! The only thing that can go wrong with a hand plane is tear-out on the edges when the plane blade leaves the wood and goes into space. You can prevent this by either planing inward from the edges to the center of the board, or by clamping sacrificial pieces of scrap wood to the sides of the board before planing - the scrap wood's outside edges will be torn-out at the end of the cut, but your board will be protected. Since you are new to woodworking, I would HIGHLY recommend that you look into owning a hand plane or two (one for face/edge grain and one for end grain - they use different blade angles. For this project you only need the low angle end-grain plane). Hand planes will take you to a whole 'nother level of accuracy and surface finish. Check out a few suppliers like Lee Valley or Lie-Nielsen (he's expensive, but it's an investment for life). Surfacing one of your cutting boards should take 5 - 10 minutes with a hand plane, not an hour per side! Of course, if you LIKE sanding for hours, and spending money on sandpaper, dust collection, band-aids, eye protection and hearing protection, have at it! I'd rather make a few passes with a block plane, with soft music playing in the background :&lt;)
When you're right, you're right. Today I tried using a newly sharpened hand plane, and even without knowing what I was doing I was able to get one pretty flat side in just a few minutes. Then another member came by and showed me how to adjust and use the plane, and the rest of the work flew by. <br> <br>As you said, it took me about 10 minutes to accomplish what took an hour or more with the sander. I won't waste my time with the other methods anymore - unless a drum sander happens to fall in my lap. The plane I used was a standard angle, though I could see how a low angle plane could make the work even easier. <br> <br>This will definitely change my woodworking. I think the first time I tried using a hand plane it must have been dull and / or poorly adjusted - so I just figured it wasn't the right tool for the job. I'm glad I was wrong.
Yay! A Convert!!! Please do yourself a favor and look into hand tools - they are incredibly veratile and accurate, with none of the safety concerns from power tools. Also, the final finish of the wood will be different! Sanding makes millions of little scratches and &quot;mushes over&quot; the grain; sharp cutting tools cleanly cut the grains of the wood, producing a luster and clarity that sanding can't do. <br> <br>It's sad that the power tool manufacturers have convinced us that we need power to do woodworking (I would, too, if I was selling power tools). The opposite is true - hanad tools are faster, more accurate, and produce a finer finish than ppowwer tools can. Think of the power tools as yoour &quot;coarse&quot; tools, doing the bulk rough work to get near your final dimensions, then use your hand tools as &quot;fine&quot; tools - tweaking the dimensions within thousandths of an inch (if you need that accuracy) and leaving an unparalleled fine finish. <br> <br>I know your handle is WorkIsLove, but with hand tools, you can change it to LessWorkIsMoreLoveAndAPerfectFinish. Please look at the vendors I mentioned, buy a low-angle plane, throw away your sander and the endless costly pads, belts, etc., and have fun working wood.
I decided to write from the perspective of a beginner because I figured, even if I miss a few things, it's possible for me to bring up common mistakes made by all beginners with the (sometimes painful) lessons fresh in my mind. Hence my warning about the exploding strips the first time I cut with the miter saw. <br> <br>Truly, thank you for your constructive criticism. Comments like this help both me and the instructable improve. I will update it as I learn more.
I ignored them for this instructable because I have ZERO experience with them and don't yet know where to begin. I just started woodworking for the first time in my life a few months ago, and San Francisco Techshop's power tool selection is A LOT better than their hand tool selection. They have a $10,000 CNC machine, but until last month didn't have a good set of hand planes. The problem is that every time they get good hand tools people tend to abuse, break, lose and maybe even steal them. If they can take care of their newest set I will try to learn how to use them.<br><br>Or perhaps I'll invest in my own. But right now I don't have the money to go buying tools without knowing what to look for. Early on I walked into a Woodcraft store, but the selection was so large and confusing, I had no idea what to get. Shopping online is even worse - everyone has opinions and advice, and they are all different. I plan to get a few projects under my belt before I go buying my own tools. After I know what type of woodworking I generally want to do, then I'll know what to ask for when I go shopping.
This is one of the best "I made it at techshop!" instructables I've seen yet. Thanks for really taking the time to explain your project. I just took the tech shop wood shop class and have been exploring with some basic projects to build my skills up - this is a great one for me to stretch myself on. Thanks!
Glad to help! That's exactly what this project did for me. I wish you good luck on your boards!
Just a quick safety comment: In the 3rd paragraph you say that if you don't have a crosscut sled, use the miter gauge with the saw fence as a measuring stop. DO NOT USE THE MITER GAUGE AND THE FENCE AT THE SAME TIME! This is asking for kickback, or if you're lucky, just having the cut piece shoot back at you. Using both together allows the cut off wood to get trapped between the blade and the fence - very bad news. Simple solution - clamp or tape a piece of wood to your table saw fence in front of the blade, and use that as your measuring stop. The key is that the stop block does not extend back to the blade - it only has to be a few inches long, clamped to the fence in front of the blade, not near the blade. This way, you put your piece in the miter gauge, slide it against the stop block on the fence, then when you push the piece forward towards the blade, it no longer is in contact with the stop block, and therefore can't cause the problem.
That's a good point, I had hesitation when writing that, but I've seen other accomplished woodworkers do it, so I wasn't sure. I've updated my 'ible pointing to your comment - I'll try to add a picture at some point when I have the time. Thanks!
Forgot to mention - this problem does not happen when you use a cutoff sled because the cut off piece is firmly held in place by the sled and the (moving) stop block. Without the sled, using the miter gauge, the cutoff piece has no support - you are pushing the uncut part through the blade, and near the end of the cut, the cut off part has no support. If it's against the (stationary) fence, friction will make it twist into the blade. And at the end of the cut it's hitting the back of the blade which is rotating at you, not downward as in the beginning of the cut. Guess what happens? <br> <br>Nice Instructable - stay safe!
Work- Your boards are beautiful and your attention to detail is great! If I can add one thing that might speed up your finishing process....When you apply the mineral oil, rub it into the wood with gloved hands (I use nitrile disposable gloves myself.) It takes a bit, but eventually the wood soaks it up. After two or three coats, check the bottom of the board to see if it's &quot;bled&quot; through. If it hasn't, keep on truckin'! If it has, flip it over and start the process from that side. Once the board won't accept anymore oil, you're finished, and you can just let it dry. At this point, I normally set the board on it's side, so if the board &quot;weeps&quot; any oil, I can wipe it off the next day. Hopefully, this saves you some time, and great work! Please post others!
Fair enough, I have one more board unfinished, I'll try it your way.
Work, please understand that is was not a criticism at all, just an attempt at saving you some time. (I'm a teacher, and that comes at a premium!) I myself am using your methods to teach my students some new tricks!
I didn't see it as criticism at all. I'm always still learning, so I like to hear others ideas
Phenomenal work and explanations! Hopefully, going to try this soon!
Glad to help, go make some awesome boards!
My father-in-law has been making these since woodshop in High School in the '70s (pre-computer era).
Oh yeah, these things are classic. There's no need for computers, they just make things quick and easy.
Your boards are gorgeous! This is a great walkthrough, too. I really need to take some of the woodworking classes at Techshop, that's for sure!
Thank you!
Great instructable! I loved the suggestions, research, alternative methods, and supporting information! <br> <br>
Thank you! I tried to include everything that helped me along the way.
About This Instructable
217,353views
405favorites
License:
Bio: I'm a long time tinkerer and lover of Instructables, but recently I joined Techshop in San Francisco, and decided to really get creative. Right ... More »
More by workislove:Shoe organizer bench Wooden drawer pulls -  made at Techshop Do you wanna build a (laser appliqué) snowman? - made at Techshop
Add instructable to:
