Nonetheless we have a feeling of winter as it should be.
For this winter we made an interactive cap with two colors of white fabric.
The cap gives an idea if warmth and cosiness in the cold.
When daylight diminishes it starts to twinkle. There are led's inside of a third kind of white.
The bright led's diffuse their light in a subtle way in the white materials and reinforce the idea
of warmth within a cold environment.
(The pictures actually do not show the effect in the right way, to get the led's visible on the images the effect is exaggerated.)
Remove these ads by
Signing UpStep 1Needed: tools and materials
soldering device (suited for soldering small parts, like led's)
pincher (for the wiring and removal of led legs.)
needle and thread
knitting gear
materials:
wool of two kinds and colors (in this case two whites)
Some fabric for making the inner hat with the led's
an atmega328 or other comparable microcontroller chip, with sufficient digital PINS and one (or more) analog PINS.
led's and wire (used here is the kind of wire with a very small diameter, very flexible and good to use in clothing).
2 AAA batteries in a battery holder, the cap is running on 2.8 Volts.
assistance:
a mum or an aunt to knit the cap :-)
programming:
for programming the microcontroller I have used a programmer like avrisp mkii
the chip is a atmega328 running on its internal clock 8MHz (set the fuses carefully!)
here is the file for the project, if you do not want to make it yourself:
http://www.contrechoc.com/instructables/twinkle_winter_cap_project.zip
comments
Add Comment
Kiteman
says:
contrechoc (author)
says:
Add Comment
