Now you want to make a beautiful platter of deviled eggs with nice neat whites and centered yolks... what to do?
It's as easy as stopping by the local farm market and buying some fresh free range eggs from a local farmer and following these steps to perfectly boiling your fresh eggs. (or go one step further and put some happy hens in your backyard, but that is an instructable for another day)
Remove these ads by
Signing UpStep 1What you need
Pot with enough water to cover the eggs
Slotted spoon
Timer
Colander
Bowl of ice water
Easy peel eggs every time fresh or old.
Just out of curiosity, did you have your eggs chilled before you boiled or room temp..mine are just out on the counter so I started at room temp and it worked but if it's even easier when they are chilled I am all for that!
I've heard all these tales about starting in cold water, cooling immediately after cooking, using older eggs, but I never got consistent results or had enough eggs to gather proper data; I'm not convinced that any of them are more than "old wives tales."
I've never tried putting the boiled eggs in the freezer, making them that cold would help pull the membrane away from the shell also, did the partially frozen eggs end up a little rubbery?
Cool instructable, Thanks.
Maybe try putting your eggs into the boiling bath, reduce the cook time (obviously) and finish with a quick cool wash instead of the ice bath. That should make them easier to peel than the standard method of starting your eggs in cold water and bringing them to a boil.
Good luck :)
Or pickle them?
L
Unless they use the words "use by" then its 45 days from date the carton was packed.
http://www.fsis.usda.gov/factsheets/focus_on_shell_eggs/#18
They have to be inspected before they can be sold but "Grading is voluntary"
