Making of a Segmented Vase - I Made It at TechShop
36,258
197
36
Published
Introduction: Making of a Segmented Vase - I Made It at TechShop
I wanted to explore wood turning and make a huge vase. To figure out how it works and avoid all the usual pit falls, I wanted to make a small scale vase first. Little did I know that what I made as a prototype would be the one i will eventually display in the show at university. So this little vase was done with only intentions to learn and experiment, with no thought on how it will look or fright that it might fail.
The first step on making this was the design. I will illustrate multiple steps I went trough, and how and why I did them.
I took student membership at Techshop (www.techshop.ws), so I can use the facilities. I took a SBU for wood lathe and went to work. I got some personal tools for advanced hollowing.
Step 1: Design
I decided on segmented vase as no more one is limited to the size of the wood one can find. I wont mention the disadvantages, but there are lots of advantages, like having no end grain to bother with, using all the scrap wood, etc, etc.
Segmented vase is made by putting together pieces of wood, to make a rings, stack the rings, and then turn them on the lathe. Hollowing becomes easier, but the design is constrained after you start.
The design is first created as a half section. This is the shape of the vase or bowl you have in mind. I roughly used the thickness and the width, I will need to have sufficient overlap between layers. I decided to make each rings with 12 segments (each segment is a regular trapezium, with an included angle of 30 degrees). I tested my math skills, and just to be sure, by cutting some foam core and putting them into a ring.
I made the a CAD file (this can be done on paper with a ruler and pen too) and took a 1:1 print of the segments i have to cut and number of segments i have to cut.
Step 2: Buying Wood and Prepartions for Cutting Segments
I went to woodcraft and choose alder and poplar and bought a couple of board foot of 4/4 planks. they had good grain, no significant knots, almost of the same hardness, and good contrast in color. Also, they cost less, at least less than walnut and maple, which were in my mind for the next version.
I planned one face on a planner and cut to equal widths of 1 inch on a table saw. The idea was to cut them into segments on a miter saw. I can set the miter saw to cut a 15 degree angle and keep flipping as I cut to get a consistent length and angle for all segments.
I test cut some pieces to see how the miter saw performs and to check its accuracy. Its hard to control accuracy of a equipment used by everyone or use a jig for long duration which the project calls for (you can cut everything at once, but loose out on the liberty of correcting for errors as you go).
Easier tests like cutting three pieces and measuring for 90 degrees on a square is good first check.
Step 3: Making of a Jig to Cut Segments
The miter saw requires a jig to make sure you can cut consistent lengths and precise angles every time. Taking 1-2 hours to make sure of this is worth you time (even if you have to do it everyday in techshop).
So I set about making a jig to cut segments. The important thing is to realize that not everything about the segments need to be accurate. Some dimensions need precision and then some need just consistency. Putting your efforts in the right direction is important. For example, Having an exact angle is important. If you err, more than a tenth of a degree, the ring will have gaps(either on the inside or outside, depending on the error). The length of the segment on the other-hand, need not be accurate, but consistent. A change in length, will only change the size of the ring slightly.
The jig is a simple one. It has a stopper, a MDF backing to hold everything together and to avoid burrs from exiting blade. Later version have a hold-down clamp too.
To check the jig, I cut some scrap wood and check the roundness of the rings. which turned out pretty good. This is followed by cutting all the segments, labeling them and making sure everything has couple of spare segments.
Step 4: Glueing the Segments
The gluing process is one which requires a lot of patience. In tis little vase i was doing I had to glue up 154 pieces together. How is it done?...one at a time.
I started by making them into pairs. The glue i used is titebond. The curing time is just about right. and its water soluble, gives a very good bond too. I used the sliding method of gluing to avoid air gaps and used more glue than required. Rubber bands were used as clamps to hold them together. Once the pairs are dry, i glued them into half rings and made a fast jig to ease the process of using rubber bands as clamps. Now, with later learning, i feel hose clamps are a better alternative when making bigger rings.
It doesn't take long for the glue to cure considerably. You can remove the rubber band in about 30-60mins depending on the temperature you are working in.
Once the rings are all done, Major chunk of the work is done. You can start to look forward to the turning on the lathe.
Step 5: Planning, Glueing and Stacking the Rings
Each ring now has to be planned and glued to the next ring. Its crucial that there are no gaps, as this would lead to  a vase with a crack. There are several ways planning can be done. you could sand them on a disk sander carefully, run them through a plan sanding machine, use the lathe and ace turn it.
Sanding disk: easy on small rings.
drum sanding: did not try this. Dont have one. Can try the planing machine may be.
lathe: very good for big rings. Use hot glue gun and stick the ring to a plain piece of MDF. Use a old scrapper and remove the first layer which would be mostly glue and just unevenness. The next level of accuracy is needs a bit of work and dealing with safety hazards. I pasted sanding paper on a board and put my weight on the ring. It really flattened it perfectly. A good way to check is with a ruler. Lay it diagonally over the ring and check for flatness. Now, flip the ring and flatten again(this can be avoided as you stack up and you have two chucks/mounting plates).
Use glue and stick rings with each other, one after another. You can also use the tail stock of the lathe for clamping pressure. as you stick rings, its easier to remove bulk of the material from the inside. You can do this later, if you have the right hollowing tools.
Step 6: Glueing the Two Halfs
To avoid the hollowing tools, i created two halves, roughly turned on the inside and glued them up. Now i have a moderately smooth insides. The outside is now turned to shape. check the thinness for evenness as you turn.
You can begin to use # 60 or #80 grit sandpaper to smooth the curves. Once the shape is close, start using progressively finer sandpaper grits up-to about #320 or #400.
Step 7: Finishing
finish with tung oil. Wet sand again with #320. Wipe excess oil after 30 minutes. Now buff using any fine abrasive and give a final polish by loading the buffing wheel with some beewax.
After some 80-100 hours of work, you will have a beautiful vase to show for the joy you had in making it!
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    36 Comments
    You may not still use this sight as this post is old but i was wondering if you still have the CAD file handy
    hello sir,
    i am deepak kumar from India and i am working on urn design but i have not technical knowledge and i wants know that how you calculate these segments of vase on graph paper and how you plane this on paper or divide this products into segments please kindly help me for making this sketch on paper like your drawing.
    very nice!!! I whant to make one for my grandma. she will love that. can you tell me what the radius is from the top and the bottum or can i have your IronCad file??
    Hi Pegasos,
    I made a file in alias. the approx radius near the top is 2.5" and at the base is 3". i used this reference only for making the blank. Turning is done by the eye. Initially i was thinking of having a laser cut template to match as i turn. Turned out that, it was easier and more relaxing to do it by the eye.
    Its a good thumb rule to avoid any flat surfaces on the vase profile. Don't have the CAD file I made handy. I can find it if you still need it, once the quater ends (the projects and courseworks are piling up as its end of quarter!)
    cheers,
    Ravi
    that would be great!!! can you send it to poppedot@live.nl?
    This is incredible. I can't wait till I have some free time to make this!
    Bravo!
    Nicely done. Woodturning is a wonderful hobby. Segmented turnings have excellent potential and are a great method to use up all the cut-offs that'd otherwise end up in the trash, the fireplace, or in that huge box hidden under the basement stairs (my favorite).
    Thank you. It's quite soothing to just see the chips fly! Nothing like putting to use all the scrap prices of wood and turning something. Had a lot of fun making this one.
    I'll try one of those eventually. I'm only beginning to do bowls and learning to hollow.
    The first time I was trying to hallow, my hands were shaking as I did not even see where the tool was touching, how it was touching and constantly thinking it will catch now...now...hahah.
    Now if I have doubts, I just turn off the lathe position the tool and turn the peice by hand and see how the tool cuts and see the chips.
    Looks gorgeous. How thick are the walls of the final product?
    Thanks! It's about 1/4 to 3/8 of an inch. Insides are not as smooth as the outside.
    That's so gorgeous I almost want to go out and buy anything that looks like it. 8-)
    Simply Awesome
    That really is a beautiful result - but in some way I almost prefer the shape in the first picture in Step 5 ;-).
    Earlier in the year, I started experimenting/doodling vases in SketchUp - I think I'll return to it and see what I can come up with...
    Thank you! It had an interesting pattern in step 5... I was holding it that way for while, when I was working on another project.
    Sketchup or any cad is useful. I had a cad curve and template, but ended up turning it by feel. It's way easier that way.
    I'm sure it is easier - and more fun - turning by feel...
    Unfortunately, as a 47-year-old unemployed (since school) man, I have no experience of (or access to) working on a lathe, so have to content myself with SketchUp.
    I do keep looking at 'build your own lathe' articles and Instructables, but I know enough to know I can't build anything well-enough to be safe enough. That's partly a lack of experience, but mainly because of my hand-strength and dexterity issues.
    Still - maybe one day...
    Thank you for this instructable. I've been wanting to try a segmented vase after taking the lathe class. I'll definitely be looking back to this post for inspiration.
