3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Making oil lamps and candles for free
Step 2Making a paper wick tallow candle
You can make a tallow or cooking grease candle very easily with the stiff paper wicking described earlier.
1. Select a jar, wide mouth jars are easiest to light.
2. Make a spiral from some wire, a foot of unwound ground wire works very well.
3. Pinch the wire around the wicking so the wick stands up. That way the wick will stand straight even if the grease melts. Where as, regular candle wicking would just fall into the candle.
4. Melt and pour in your grease, wait for the grease to solidify, then your candle is ready to use...
8 comments
Apr 4, 2012. 3:26 PMlomi.hija says:
it would be nice if you can make the wick float, so it will automatically follow any level of oil you have..
May 18, 2011. 7:49 AMbowow0807 says:
i think you can by using one of those tiny candles in the small tin used for boiling scents. just punch a hole and place the wick through the hole and it will float
Dec 14, 2011. 10:30 AMCatl8dy says:
You can! I tried it and it works great. Thanks for the idea :-)
I used a Kerr jelly jar.
Punched a small hole in the center of the metal candle holder, twisted in my
salted paper wick, floated it on top of the oil and waited for it to absorb the oil. Took it out with a needlenose pliers, lit it while holding with the pliers, and put back in the oil.
The wick was about 1/8 above the metal and the extended about an inch
below it, into the oil.
Oct 22, 2009. 5:16 PMKnitwitz says:
Wow, great idea, Thank You, so much for your knowledge.
Oct 12, 2008. 12:05 AMStarrystar says:
Is there some alternative to grease for us vegetarian types? Maybe crisco or . . . something vegetable based? (wishful thinking, maybe.)
Aug 22, 2009. 12:10 PMrbneville says:
you could probably use algae oil too.
Oct 30, 2008. 4:15 PMshmacky26 says:
This worked perfect for me the first time, I used a coffee filter to filter olive oil after cooking chicken. The only problem that I ended up with is that my wix, made of paper and salt, burns black smoke after it really gets going. Not sure why, but it's too smokey for indoors. Any suggestions or comments on why that is happening? Also, Is there something you can mix with oil to get it to smell good that's not store bought? Maybe grinding up dried rose pedals to a powder and mixing it in with the oil?
Aug 22, 2009. 12:12 PMrbneville says:
Just get what you want your oil scented as. Fore example a rose flower. Place it in the oil and keep the oil warm for a day or 2.( I found placing it on top of a heater works good). Then filter and use.
Aug 25, 2009. 1:28 PMtexasmom_35 says:
To keep the oil warm do you think that placing it on one of those candle warming things would be ok?? I use it to make my yogurt and when used with a small plate between it and the yogurt it stays at a perfect 110 degrees.
Dec 5, 2008. 1:02 PMcrochetdee says:
How long can you burn? does the glass have a point where it get too hot and will break? or the oil can bubble/sizzle up? By grease: did you mean bacaon fat? thank you. PS: I add scent to candles, you use less when then candle wax is a little cooler, otherwise you're cooking the scent. spearmint and sage is great for headaches, nausea, muscle pain rosemary, mint and sage great for extreme muscle aches Pine for colds. mix in a scent you enjoy, like rose, is you don't like the smell or want to add softness to a medicinal mix. and remember, it won't cure your headache if spearmint gives you one. these cures work by being absorbed thru skin or nose, but being harsh smelling isn't the same as haing a Negative reaction. Aso, these are medicinal. watch how many drops you use and how much COMBINED oils you take throughout the day. AND ALSO MAKE SURE TO AVOID oils that are Expellants!!! they're good for getting rid of congestion and BABIES. Just don't buy them.
Oct 20, 2008. 11:57 PMiarkus says:
My grandma used to just perforate lid of a jar and insert wicking through hole. you can fill the jar with just about anything - grease or wax of any kind. As long as there is enough oxygen, it will burn for a long, long time.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
20
Author:steam_cannon(michaelcasper.com)
Hi There! I'll tell you a little about myself. I'm a maker and doer. I like sharing my experience, building hardware projects and all kinds of art. I enjoy woodworking, pottery, fibercraft, metalworki...
more »
