Making sneakers from scratch
 by prushik
(by "from scratch", I mean from fabric and other things available at any local craft store)
Hi everybody, about 5 months ago, I decided to move from my hometown (Philadelphia, PA), to Daegu, South Korea. Before I came, I asked some Americans living in Korea about what I needed to bring (things they don't have here in Korea), they all said about the same things, deodorant, socks, toothbrush, and shoes. Everybody said I should make sure I bring enough shoes with me because Korean shoes are made for Koreans, so for some reason, Korean shoes just don't fit Americans correctly.
Of course, since I am not the kind of person that can tolerate being limited by the available retail products, I decided to make my own. Turns out, it's not so hard.
I looked up other instructables, but none gave me the info I was looking for, some told me to purchase soles and glue them on, which made me feel sad inside, and another said to use cork for soles and that I couldn't ever wear them outside or they would break, yet another said I should first make a casting of my feet, which is probably a good way to do it, but there is no way I want to do that.
So I started from scratch. Bought some crazy colored suede type fabric, took some loose measurements and started sewing, at which point I realized that I had no idea how to sew, so I looked up an instructable about sewing knots and that type of thing, which was a big help, but I'm still no seamstress (or seamster??). I had almost completed one shoe when I had to leave for Korea, now I've been in Korea for 4 months, and I just got around to starting the second shoe, but this time I'm remembering to take pictures so I can write this instructable for you guys :-)
Step 1: Gather your materials
Basically you need the following:
-Suede or leather type fabric (something of that strength, can be fake if you prefer)
-Some other kind of fabric (doesn't really matter)
-Thread
-Plastic sewing mesh stuff (I don't know what its really for, but its good for making shoes, and all craft stores sell it with sewing stuff)
-Sewing needles
-Fabric scissors
-Measuring tape
-Polyester filling (or some other filling if you prefer)
-Foam sheet
-Felt (probably unnecessary)
-Laces
For the sole, I used:
-Liquid rubber for carpet backing
-Paint brush
-Foam sheet (Thicker, I actually used a flower pot holder for this, it was the same material)
Optional:
-Eyelets
-Eyelet tools (eyelet anvil, eyelet tool)
-Hammer
Choose your fabric colors wisely, I fully endorse using the most bright and obnoxious colors available, the world needs more of that. The suede or leather is for the outside of the shoe, if you didn't guess that already. Also note that I used a pre-existing shoe for the measurements, which I assume is what you are wearing now.
For the sole, you might want to try other things, but I know the carpet backing worked pretty well for me. The stuff I bought is made by SAF-T-BAK. I know many craft stores carry liquid latex for making molds, but I don't think that is as strong. Online, you can find better rubber making kits which involve mixing stuff together, but its quite a bit more expensive than carpet backing. Liquid latex for molds is also much more expensive.
k24tea says: Jan 28, 2013. 3:15 PM
Thanks for sharing this great Instructable! Well done with clear directions and lots of helpful photos. How are the rubber soles holding up to wear?
prushik (author) in reply to k24teaJan 29, 2013. 5:54 PM
The wear isn't the issue so much as the strength. They hold up ok as long as you let the rubber cure long enough. However, if I were going to do it again, I would use something like Oogoo (http://www.instructables.com/id/How-To-Make-Your-Own-Sugru-Substitute/) or a bioplastic (http://www.instructables.com/id/Making-BioPlastics-Environmentally-Friendly-Plast/)
jessyratfink says: Apr 6, 2012. 10:48 AM
That's awesome! This is a great walkthrough - lots of good ideas for shoe making.
prushik (author) in reply to jessyratfinkApr 6, 2012. 6:51 PM
Thank you very much :-)
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
