3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Making wooden sandals (Scholl's style)
Making wooden sandals (Scholl\
I like wearing Dr. Scholl's wooden sandals, but I can't find them (men's) in the shops anymore. So I decided to try making a pair by copying the shape of the original. The distinctive feature of this style of sandal is the ridge or or bump that fits between the ball of the foot and toes, preventing slipping. The back is also carved out which stops the heel sliding sideways. The strap is well forward, allowing the foot to rise naturally on the toes when walking. Pressing down with the toes to "retrieve" the sandal while stepping forward produces a distinctive "clop, clop" sound.
I believe Dr. Scholl designed the original sandal carefully, based on a study of the natural barefoot gait.
Later versions, especially in women's styles, diverged somewhat from this ideal.
This shows the finished sandals (a bit dirty; I've been wearing them in the yard).
Total cost: about $25 ($5 for the wood, $20 for a commercial sole). Using an old car tire for the sole might work - I tried, but had trouble cutting the steel belting.
Step 1The original sandals
I have several pairs of the original sandals, in slightly different styles as the manufacturer changed them over the years. There are 3 basic problems that develop:: the straps wear out, the woot splits along the grain, and the wood wears rapidly if the rubber sole wears through and I don't get them re-soled promptly. The upper surface also wears down gradually, so the wood can get quite thin at the toes and break. That's what happened to this pair.
28 comments
Sep 13, 2011. 11:00 AMrichie_114 says:
I've been using an old leaf blower as a dust collector, Well..... It shoots the dust out the window of my shop into the woods by my house.... makes good mulch as long as I don't let walnut dust go out there too.
Sep 13, 2011. 10:56 AMrichie_114 says:
Way too cool! You essentially took a pantograph and made it simpler!
Finally! something to do with that "portable drill press" (same as yours I'm sure)
I was about to toss it in the trash since it only works well if I bolt it to the piece I'm drilling.
Jun 9, 2011. 4:57 AMPatent Dragon says:
This could be along the lines of what I've been thinking of doing - carving some soles for a pair of boots I'm planning to make. When I have the time, and the opportunity to acquire some tools, I'll see how far this will take me towards my target.
Thanks muchly in the meantime!
Nov 29, 2010. 9:44 PMunjust says:
lovely! the tool you've built is known as a duplicating machine in several industries. they were used before CNC for limited run rapid prototyping (and even some production work, you could get 6 or more routers going off of one template). you build a master, and then you duplicate that first starting with a larger router bit to rough out the shape, and then going over that with a finer bit to eliminate surface notching. it's important to match the probe to the bit you're using.
wooden type was often copied in this manner.
Jul 19, 2009. 11:20 PMironsmiter says:
Nice writeup and a cool concept... but GET THEE A CURVED DRAWKNIFE!!!
so commandeth the woodworking gods, and trees alike!
A good Convex Spokeshave would also do wonders(and probably be cheaper). Either of these, with a little practice, should shave 90% of of the time it takes you to contour the wooden sole.
How are they to walk on? I foresee some cushioning issues, when used on modern concrete walks. Indoors, on carpet, or outdoors on lawn, probably fine...
Oct 27, 2010. 11:02 AMGoedjn says:
There are different kinds of curved drawknives. You want the kind that's designed for barrel-staves, and/or chair seats.
Jul 20, 2009. 3:08 PMironsmiter says:
Ahh, so the curves are deeper than they appear in the finished product images. The shoe I really have always wanted was the Birkenstock sandal (cork sole, rubber tread, leather upper). Sadly, their widest size is a "regular"(D-EE) And, even with a EEE, I have to buy shoes at least a whole size too large. Bad mojo in an open toe sandal. My own mother used to say we'd have better luck fitting the shoeBOX to my feet, than the shoes themselves. Moccasins only get me so far, and they wear quite quickly... and clown-shoes don't exactly inspire comfort. Since I can't even FIND the men's "exercise sandal" section on the Dr's website, I suppose I'll fire up the printer, spit out a few of your images, grab my hook knife, and see what i come up with. Nice soft pine 2x4 should be good for a prototype, then on to walnut burl or oak, for a finished product. I hope. maybe. Thanks for your 'ible and replies!
Oct 28, 2011. 5:33 PMDeadlyDad says:
I don't know if you are going to see this, but I found this site about moccasins and DIY sandals, and thought that it might interest you.
Oct 31, 2011. 8:43 AMironsmiter says:
thanks.
Yes, I HAVE seen THAT site before(and a few others).
I have even made 3-4 pair.
they are just never very comfortable.
I did make one pair that was comfortable to stand in, and used them for a while as cooking shoes.
I used a section of semi re-tread that i found on the side of the road.
The rubber just wasn't flexible enough for comfortable long-distance walking though.
Nov 2, 2011. 8:45 PMDeadlyDad says:
Semi tires? YIKES! No wonder they weren't comfortable; they are very hard, as they need to last a long time, supporting heavy loads. Drop by your local race track or tire store and score some worn out soft racing tires.
Nov 3, 2011. 5:20 PMironsmiter says:
problem i ran into with other tires I've tried is...
They're still not flexible enough, and have too sharp of a curve to them.
Trying to walk on them is like walking in those "tone your butt and legs" shoes from sketchers. Just horrid.
The semi-tread had the advantage of laying flat.
that's why I tried it.(that and it was free).
Jul 25, 2009. 4:35 AMPuffer49 says:
Scholl Pescura sandals were available in the UK in men's sizes up to UK12 (Euro 46) until recently. They are not very accurately sized, however; the 46 is barely a UK11. Scholl was selling them discounted to £10 before Christmas 2008. They do now seem to have disappeared from the website. But I have seen them at two branches of TK Maxx and last week bought a black pair in size 46 reduced to just £7.00! If in the UK, it might be worth searching at local branches of TK Maxx.
The Birkenstock Madrid is a generously-sized alternative (45 = true UK11 and quite wide) and very comfortable. Available in UK in black up to 46 from Amazon (about £30); they were cheaper when on special offer last winter!
I wish the original Berkemann B100 was still made and available in the UK; the current models are apparently not so good and are very expensive (about £50).
Jul 30, 2010. 1:31 PMwhiskeywaters says:
Rubber sole - bike tire.road tire Strap can be made using the innertube - completely recycled.
Aug 15, 2009. 2:24 AMgearhead1951 says:
do a search here on instructables for " 3 axis dremel pantograph " , It looks like just what you need for this project !!
Jul 25, 2009. 7:16 AMprawiranegara says:
hey in my country (Indonesia) its called "BAKIAK" sandals. its a traditional sandals from Indonesia.everyone will hear you while u walking.haha...
Jul 20, 2009. 7:12 PMdiscontinuuity says:
Pretty cool. I don't have any of the wood working tools that you do. Maybe I could make a form-fitting wooden sole by building up veneer into plywood on a foot-shaped form. I'm thinking that you could make a cast of your footprint in sand or plaster then make a form from resin or plaster and make the plywood off of that.
Jul 20, 2009. 1:59 PMMtalus says:
As a woodworker with size 10, 6E feet I've also made my own; that was before the internet and the ease of online orders in my size made me lazy. I wish I could remember just how I jigged a pantagraph router setup to copy a cast of my foot (a simplified contour plaster cast). I made the uppers from leather, boot profile, and the rubber on the sole was old conveyer belt. They were great and insulated my feet from a cold floor. Later I met a man from the UK and they really brought back memories for him. Ironically I had never heard of alder soled dairy clogs but that's what I had made (according to him, still awaiting confirmation). He then gave some info that improved them: A band of brass set perpendicular to the sole around the heel and toe, depending on where your sole wears most, will really help them last. It would scar up a floor I'm sure but that wasn't a problem in the barn or shop.
Jul 16, 2009. 4:29 PMLithium Rain says:
:D I was just thinking last night that I should make some sandals with wooden soles. Freaky! 5 *s and faved. :)
Jul 16, 2009. 3:13 PMcorey_caffeine says:
for soles another non-scuffing option is to go traditional using thick leather and small tacks to secure it
Jul 16, 2009. 9:33 AMthewoodcarver says:
Nice work , I do remember these and wearing them out over the years
Jul 16, 2009. 8:50 AMbustedit says:
nice job. we called these "clogs" when i was younger. my friend, Red, got kicked in the cohones by a girl @ recess with a pair of these on, yikes.
Jul 16, 2009. 7:56 AMjolshefsky says:
A friend of mine taught me a "trick" of coping using an angle grinder for metal (and, preferably, with a sanding disc installed). It seems that might be useful in making these, although the pantograph-mill device is pretty cool.
Jul 16, 2009. 7:46 AMve2vfd says:
Holy cow! I haven't seen those sandals since the early 70's when everyone used to wear them! What a trip down memory lane. Excellent instructable, super clear and detailed!
Jul 16, 2009. 2:27 AMthearchitect says:
Wow! Excellent work, very clever routing routine! Thanks for sharing! K.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
37
Author:adaviel
