3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Making wooden sandals (Scholl's style)
Step 10Sanding the upper surface
The upper side of the sandal is sanded with a high-speed disk, removing the ridges between the tracks cut by the router and generally smoothing things out. The high-speed grinder is quite hard to control, so it is important not to allow it to remove too much material. Following the initial sanding, I repeated with a slower-speed disk (disk mounted in a variable-speed electric drill), and finished by hand with a medium-grit sandpaper.
There is a vacuum set up to one side of the work, with a large funnel to try and catch the dust. It was only partly successful. This sander makes a lot of very fine dust that gets on everything. It would be better to do this outdoors, or in some kind of booth where the dust can be better controlled.
1 comment
Sep 13, 2011. 11:00 AMrichie_114 says:
I've been using an old leaf blower as a dust collector, Well..... It shoots the dust out the window of my shop into the woods by my house.... makes good mulch as long as I don't let walnut dust go out there too.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
37
Author:adaviel
