Introduction: Male-Male, Female-Female Garden Hose Adaptor
Recently i had to connect two garden hoses together but they had both male ends. You can buy an adapter for about $15 or make your own set for $10. For about $5 ill show you how to make a Female to Female garden hose adapter.
Step 1: Parts
Not much you need just 2 Female hose couplings and about 6" of garden hose
Step 2: Cut Around 2-4" of Garden Hose From the End of Your Hose
Cut around 2-4" of garden hose from the end of your hose
Remove the couplings from their packaging
Step 3: Assembling Step 2
Assemble the pieces, and tighten the clamps.
(not much else i can say)
Step 4: Assembling Step 3
Attach a coupling to the end of your garden hose if you want to still use it.
MAKE SURE TO USE THE SAME SIZE HOSE AND COUPLINGS
In the picture i used a 3/4" coupling on a 1/2" hose, the coupling should fit snugly in the hose. If you have to force it in its to big, if it falls out its to small.
Step 5: Done
That's pretty much all i can say about this. These costed about $5 each were you would have to spend $15 for a store bought one.
Your favorites and comments are greatly appreciated.
Thanks
Matthew
2 Comments
Sir yes sir! Just what I needed, tyvm!
Not sure of the price difference but most hardware stores have hose to npt threaded adaptors. Two of required adaptors, a pipe coupling of the correct size, a bit of pipe sealant,and you don't have to worry about the hose or the worm clamps. A tee used instead of a coupling and you build the last hose splitter you will ever need.
