Step 3The switch
I'm using crimp-ons for the bottom electrical connections. The next step is the circuit diagram which will explain things further, however, notice that the ground from the light is spliced to the ground connection to the battery at the switch pole which also needs to go to ground.
The little light in the switch needs a ground to work correctly. The worst thing about the switches you commonly find is that the package doesn't specify the ground, positive and load with anything approaching certainty for a newbie to electronics. So ask the clerk if you aren't sure or look for a switch with better packaging.
This switch I'm happy with as it lights up fairly well.
As I mentioned earlier, you can use a lamp cord switch also. I like lighted because you get a reminder when your light is on. Plus it looks cool.
Add Comment
