Step 6Mounting the light
On this bike I took an old bike speedometer bracket (minus the speedometer) and put the light stake into the bracket which had a convenient taper matching the stake's taper. Then I zip-tied it.
This particular setup gets no kudos for style. I said earlier that I had cut off the back part of the cross on the stake, but I can see it's still there.
If I was to redo this, I would cut off the back part of the stake cross, drill a hole in the stake and use a conduit hanger just like the switch next to it.
As a post-project critique, the setup has a bit too many hard edges. You never know when you are going to have a body part go in an unusual direction and sharp pointed corners have a way of creating painful contusions, so upon reflection, I will round off the sharp corners you see in this picture.
Add Comment
