Introduction: Man Crafting: How to Tie a WD-40 Fly
Picture of Man Crafting: How to Tie a WD-40 Fly
The WD 40 fly is an all-use fly for fly fishing. It can be used on your fishing set up in many circumstances and conditions. To tie this fly you will need:
1) A fly tying kit that includes a vice, bobbin, and whip finisher
2) A pair of scissors
3) A size 16 straight shank hook
4) Gray 140 denier thread
5) A duck flank feather
6) Hares ear colored dubbing
Step 1: Wrap the Hook
Picture of Wrap the Hook
-Take your thread and using the bobbin, wrap a layer of twine around the hook starting from the eye of the hook, down the shaft, and moving toward the back. Stop when the hook begins to bend into the shank
Step 2: Attach the Tail
Picture of Attach the Tail
-Pull off a few fibers of duck flank feather
-Measure the length of the tail
             *The length of the tail should be about the same length as the shaft
-Hold the fibers to the hook and wrap them using the same thread
             *Do not cut the excess feather, it will be used later
             *Make sure the feather is being wrapped on the top side of the hook
Step 3: Wrap the Body
Picture of Wrap the Body
-Begin wrapping the thread up the shank toward the head making sure to cover the duck flank as you go.
-Tie the remaining duck flank back after wrapping it 2/3 of the way to the eye so it is not in your way
Step 4: Apply the Dubbing
Picture of Apply the Dubbing
-Pinch some dubbing, and with moist fingers, roll it onto your thread
-Wrap the dubbed line in the same fashion as before around the remaining 1/3 of the shaft.
            *You may keep wrapping until desired thickness is reached
Step 5: Create the Wing Case
Picture of Create the Wing Case
-Fold the duck flank feathers over to top of the dubbed portion towards the head
-Lie the feathers over the top and tie them in
-Cut excess feathers
Step 6: Finish the Fly
Picture of Finish the Fly
-Wrap the head a number of times to secure the materials
-Use your whip finisher to tie the end knot
-Cut the excess thread
CandyLove11 (author)2015-06-07
Cool!!
Infernoxan (author)2014-06-05
This is cool. We have the exact same fly tying kit too :p
bcavaciuti (author)2013-02-26
i swear WD-40 is a lubricant spray
SG1Oniell (author)bcavaciuti2013-02-28
Unsure if that's sarcasm or not, but WD-40 is. It stands for "Water Displacement (formula) 40"
A little late to the party, I know, but it could be reffering to how effective the fly is. WD-40 is a fairly effective fish attractant. When I was younger, we used to catch fish on bare hooks sprayed with WD-40(yes, I realize now that it was probably not the best thing to be doing)
givon22 (author)2013-11-24
GpgfajxmbczCvxzhkzLsS l
eyepodd (author)2013-02-26
i think this would work well on a nymph hook also :)
elkslayer88 (author)2013-02-26
it is
About This Instructable
8,781views
42favorites
License:
More by elkslayer88:Man Crafting: How to Tie a WD-40 Fly
Add instructable to:
