Introduction: Manage 3D Printer Filament Spools With Zip Ties
Picture of Manage 3D Printer Filament Spools With Zip Ties
As I am sure many people are, I am short on maker space in my condo and could manage 3d printer spools better. This Instructable came out of the necessity of hanging my 3D printer and spools out of the way when I wasn't using them. My work area is almost entirely populated by wire shelving, so unless yours is too, this idea might not be too helpful for you.
What you will need:
Step 1: Make a Giant Tie
Picture of Make a Giant Tie
Using two long zip ties, connect the ends together to form a larger zip tie. Insert this through the hole in the spool, leaving some excess to hang down along the side of the spool. This will keep the spool from tilting on the zip tie once it is hung from the wire shelving.
Step 2: Hang and Trim
Picture of Hang and Trim
Take the open ends of the zip tie and thread them around a wire on the wire shelving. Trim any excess. The spool should hang free without too much slack in the ties for lateral movement. Thread the end through the V-like wires at the end of the shelf. This will keep filaments from different spools from crossing. As you can see from the picture, the printer and spools hang out of the way when not in use, and when in use, it is a simple matter to pull the filament from the shelf end down to the printer. As the printer uses filament, it will roll smoothly off the spool.
solarborg (author)2016-12-04
why don't you make a spool insert for your spools with the inside diameter of a broom handle using the cable ties to hang it all up. I had electrical cable held up as you do and some times it would stop rolling due to the plastics rubbing together.
Ehlers_TV (author)2016-01-13
Great idea :-)
mclarsen (author)2016-01-11
what 3d printer do you have?
TheCoffeeDude (author)mclarsen2016-01-12
M3D Micro 3D.
About This Instructable
3,124views
24favorites
License:
Bio: I'm a 45 year old Systems Architect living in the Midwestern United States. After travelling the world for 20 years as a consulting architect ... More »
More by TheCoffeeDude:Pizza Wrapped Italian SausagePolynesian Pork BellyBacon and Cheese Potato Tart
Add instructable to:
