Manga (figure/part1)
219
4
Posted in LivingArt
Introduction: Manga (figure/part1)
About: Drawing manga,anime,figure,and flowers
This is my first instructable and today I will be showing you how to draw a figure for a manga/anime drawing.
Step 1: Head Scale
When drawing a figure to proportion the professional way is with 8 head height. For beginners I recommend the 7 1/2 height. What I mean by this is that each figure or drawing will be 8 or 7 1/2 heads high (ex. If you draw your head 1 cm in length then your figure will be 8 cm or 7 1/2 cm in length).
Step 2: Body
When drawing the body you should create a line down the middle of your page. If your head is 1 cm in length then you will draw your line 7 cm in length. Measuring 2 cm in length downward from the chin of the head make a small dot/mark. From the height of your chin draw a horizontal line going 0.5 cm away from your head ( if you have a different size head then measure half of your head, draw the line to where the cheek and chin line meet on a 90* angle then draw the length of half your head outward following your chin line). Create a triangle from the dot to your chin line
Step 3: Arms & Legs
Draw a circle on both corners or triangle of the chin line. Draw a line about the length of your chin line to the bottom of the triangle (crouch area) and place the line in any direction you would like. Once you have placed your line draw a circle at the end. Create a new king half the length you just create facing in any direction to create the elbow and arm.
Draw two circles a about 0.5 (half the head length)in length on the triangle less then the top of the triangle.draw a line about 1/4 of your figure height in any direction. Once you have placed your circle at the end of the line. Draw another line 1/4 of the figure in any direction to and the shin of the leg and if you want you can also draw a triangle at the end of the line as a foot.
Step 4: Your Manga Figure
Your manga figure should now start to look like a figure of a person and your now ready to draw the manga character
    • Woodworking Contest
      Woodworking Contest
    • Flowers Challenge
      Flowers Challenge
    Hello, and welcome to the Instructables community!
    It's great that you've decided to tell the world about something you've made by publishing an Instructable.
    However, your project still needs a little more work if you want it to be well received on Instructables. Projects that don't include certain basic elements tend not to get the attention that they deserve.
    Successful projects on Instructables include:
    - clearly written details of a finished project with instructions
    - proper spelling and grammar
    - pictures of the project that you took yourself
    I'll give you another opportunity to make any final changes to your project before we publish it.
    Once you're all set to go, please republish your project and send me a quick comment letting me know that you've made some changes.
    I'll give it a quick final check to make sure you're on the right path, and then remove this note.
    Also, we like to feature and reward pro memberships to really well done projects. If you want to see what we look for, check out here!
    Thanks for your submission and we hope to see your project published soon!
