Mango Stick
315
4
Published
Introduction: Mango Stick
Mango is my favourite fruit.
Using a mango stick will let you eat a mango without getting your hand spoiled.
It is easy to assemble and it requires only two parts :
1- a 3 cm. (1 1/4") stanless steel wood screw
2- a 10 X 0.8 cm. (4 X 0.4 ") plastic or wood stick.
The tools you need :
- a drill
- metal saw, grinder or clipper
-two part epoxy
Step 1: Assemly
1- cut the head of the screw
2- drill a 1 cm (0.4") axial hole at one end of the stick (slightly lager than the screw size)
3- Mix a small amount of two part epoxy
4- Fill the hole with the epoxy mixture
5- insert the screw (head cut side) in the hole
6- leave in warm place until glue setup
Step 2: Screw
1- Hold the mago firmely with one hand
2- Locate the umbilicus (navel)
3- Screw the stick until it reach the pit (endocarp)
4- Continue screwing to the end of the thread so the mango is well attached to the stick
Step 3: Peel
1- Slit the mango axially using a sharp knife in six or eight lines from the top to the stick
2- Peel gently
3- Enjoy
Nassef
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    • Stick It! Contest
      Stick It! Contest
    That's so clever! Mangos are so tasty but messy, your method looks much better! Welcome to instructables!
