Introduction: Map Coasters (aka Coast-To-Coasters)
Picture of Map Coasters (aka Coast-To-Coasters)
This is a fun little project that doesn't require a lot of materials or tools. The end result is a neat coaster that will give any room more character and a nice vintage look.
What you need:
-Old map or atlas
-Coaster(s)
-Glue
-Scissors or knife
-Pencil or pen
-Casting resin
Let's get started!
Step 1: Trace and Cut Your Map
Picture of Trace and Cut Your Map
The first thing you need to do is to get the coaster(s) you have chosen and lay it/them flat on your map. Then take your pen or pencil and trace an outline of the coaster(s) and cut it out with your scissors or knife. Then just place it on top of the coaster(s) just to be sure there is no overhang around the edges. If there is, just trim it off. Then, grab your glue and affix the map to the coaster.
Step 2: Mix and Apply Casting Resin
Picture of Mix and Apply Casting Resin
Now, just mix up your casting resin as per it's instructions and pour it over your map/coaster. I just continuously poured the resin in the centre of the coaster and let in spread until it was fairly close to the edges, and then carefully used a popsicle stick to line the resin around the edges. Make sure you don't put too much resin on or it will run over the edges and ruin the 'raised edge' look. I didn't take any photos of the actual mixing and application of the resin, but as long as you follow the instructions that come with it, it's really not difficult at all. After you're satisfied with your resin application, cover the coaster with a small box or tupperware or something just to keep dust particles and hair from getting trapped in the resin before it cures. Let it sit for about 24 hours before handling it.
Step 3: Set It on Your Table
Picture of Set It on Your Table
Done! Now all you have to do is place your coasters on a coffee table or wherever you like. Hope you enjoyed this quick little instructable!
JulianAzz (author)2015-11-20
GREAT idea! I'm definetley going to make one to add to my home made coasters!
annie16186 (author)2014-12-14
Love this idea! I made some and started using them, but I have the problem of the resin "melting" when I put hot drinks on the coasters (leaving a circular imprint), same for you? I did just use whatever casting resin was available in my local craft store. I think if I'm to make this again I would look into getting heat resistant resin.
annie16186 (author)annie161862015-07-01
So I got around this issue by putting some some clear self adhesive film on top :) you know, the sort you might cover your brand new text books in.
Battlespeed (author)2013-12-15
Didn't you have to seal the map pieces before pouring resin on them? Resin usually stains paper elements (photos, etc) if you don't put several coats of Modge-Podge or something like that on them.
ctx1985 (author)Battlespeed2013-12-15
I didn't seal them no. I didn't really notice any issues with the paper staining, although the maps are about 50 years old and discoloured a bit so maybe I just didn't notice.
Battlespeed (author)ctx19852013-12-16
Thanks for your reply. Perhaps it's something different about the paper used in atlases or something. If you do it again with different maps/paper and you do get staining, a couple of thin coats of Modge-Podge before applying the resin will take care of that.
One other question - were these coasters some sort of cork material, or what?
Thanks!
ctx1985 (author)Battlespeed2013-12-16
Oh ok that's good to know. I will definitely do that next time if I notice some staining happening. Thanks! The coasters have a thin layer of cork on the bottom and like a 1/8" hard (I think plywood) surface. They were just cheap discounted coasters with an ugly design on top that I got from a local store because they were 50% off haha.
ginger20037 (author)2013-12-04
I'm gonna have to try this to make a set for my Grandpa, love the idea! :D
ctx1985 (author)ginger200372013-12-04
Thanks! Yeah I think they would make great gifts! I'd love to see some pics when you finish!
MayCauseMadness (author)2013-12-04
Awesome! You could do this with any image. (photos of loved ones, pets, inspirational quotes, favourite authors.) Very cozy and personalized! Well done!
ctx1985 (author)MayCauseMadness2013-12-04
Thanks so much! Yeah you could do it with basically any image! The possibilities are endless :)
mtrodman (author)2013-12-04
what a great idea for a personalized gift! You can choose locations of significance to the giftee...
ctx1985 (author)mtrodman2013-12-04
Thanks! Yeah That's what I was thinking exactly. Easy to make and you can personalize it for anyone :)
northwest (author)2013-12-04
Beautiful!
ctx1985 (author)northwest2013-12-04
Thank you!
About This Instructable
10,785views
437favorites
License:
Bio: I'm a 29 year old guy who's passionate about building and fixing things, sometimes if they aren't even broken. I get a ... More »
More by ctx1985:Simple Wine Rack From Pallet WoodMason Jar Tea Cup With Built In Tea BallMaker/Work Bench From Scrap Wood
Add instructable to:
