Maple Syrup Jug Birdhouse
4,091
42
5
Published
Introduction: Maple Syrup Jug Birdhouse
Make a cute little birdhouse from recycled Maple Syrup Jug or any sturdy used jug container.
Step 1: Simple Jug Recycled Into Cute Birdhouse
Those who have seen my other item know that I believe in simple, quick and a minimum of required tools and parts. This little bird house is quick and easy and can be made by anyone in less than half and hour including finding the perfect location to hang it. Hope you enjoy.
Rather than throwing syrup jugs into the recycle bin it can be repurposed quickly and with a minimum of tools into a cozy little bird house that wrens, chick-a-dees and titmice will love. I have several in my yard and they have been used over and over by my feathered friends.
You will need
1. A jug ( I took the label off just because it was easy but some don't come off as easy---the birds really don't care.
2. A pair of pliers
3. A ice pick
4. A pants hanger
Step 2:
Remove the paper part of the pants hanger and straighten on side of the wire with the pliers. Make a hook with the other side. Coat hanger wire is tuff so be careful when trying to bend it.
Step 3: The Tricky Part
Take your ice pick and heat it in a flame; either a candle or on the stove if you have gas. While it is hot, poke a hole in the bottom of the jug on the top side where the handle is. If you are a kid, ask for some help doing this.
Step 4: The Finished Product
Hook the looped end around the handle and stick the straightened end in the bottom hole. Look for a tree to hang it in and wait for visitors to check it out.
These can be made out of all sizes of jugs and bottles for different size birds in you yard or on your balcony. You will enjoy watching the new family grow and fly away.
    • Casting Contest
      Casting Contest
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    5 Comments
    It is necessary to put a lot of branches of trees inside. Otherwise, the pitcher will become a trap for the birds. Smooth walls. They cannot go.
    The smooth, mostly horizontal walls would be fine for a small bird to navigate. If this was vertical, that would be a trap (albeit not an effective one since birds don't generally nest from a vertical tube).
    I'm not quit sure what you are saying but the birdhouse is supposed to be hung outside for wild birds. It would not work inside the house. The birds have to be able to come and go to build their nests. Also wait till spring to put it outside because it is probably to cold yet for them to start nesting.
    The wire hanger is a great way to put it up! Very smart :D
