Marauder's Map - With Hidden Footprints! (Full Size Replica)
Introduction: Marauder's Map - With Hidden Footprints! (Full Size Replica)
A couple of years ago I made a tutorial on how to create a Marauder's Map full-size replica. However, it was created using scans from the Wizarding World version, which is basically a watered down replica of the movie version. It's missing pages, has inaccurate text, and for some reason one of the pages is upside down...
I wanted something better, so I created my own templates for a full-size movie replica, complete with all the missing pages and corrected text. I did this by literally tracing screenshots and typing and transforming text in Photoshop.I did use a lot of the original scans from Little Falling Star and I also referenced other people's replicas, such as Jan Hamernik's. I swapped out the background for something that I believe looks more accurate as well. On top of all of that, I created extra flaps that open to reveal character's footprints (like Harry Potter and Albus Dumbledore), a flap that opens to reveal the Room of Requirement, and a fully reversible map cover that displays the Marauders' message to Severus Snape.
Beyond these supplies, you will also need to download and print the free templates I'm providing. These come in 11x17, 8.5x11, and A4 sizes as well as a full size template for anyone who'd like to use a plotter and skip the cutting and gluing. The templates also come with and without the background, for those of you who'd rather age the paper themselves and save some ink.
Once you have all this together, continue to the next step and let's get mischievous!
Step 1: Video Tutorial
Follow along with the video tutorial above (coming shortly), or continue through the next steps for written instructions and photos.
Step 2: Printing the Templates
The first thing you need to do is print your templates. If you're using the templates with the background texture, you'll need to print double sided. I suggest print one of the double sided pages, then holding the paper up to a light to see how well the sides match up. I got them as close as possible, but that's all based on my printer. Your printer may be a bit different. If they end up not matching up, you may need to shift the background over a bit. Or if you'd rather not deal with that just have them printed somewhere.
If you're not using the background, you can just print single sided. This is the easiest option when it comes to printing, but in this case you'll need to age the paper manually. I won't go over that in this tutorial, but Google.
Step 3: Cutting the Templates Out
I've made these templates as easy to cut and glue as possible - with a gray dotted line framing each piece and a pale strip labeled GLUE where the glue is supposed to go.
Using your ruler and X-Acto knife, cut out the templates (see the video for more details). Don't forget to do this on top of your cutting mat.
Keep all the templates in order. Trust me - it makes things a lot easier.
Side Note: you might flip your template over to see that the back doesn't quite match up with the front. No problem, just trim off the excess. Unless its off by a large margin. In that case you might need to have this printed somewhere, or go for the background-less templates instead.
Step 4: Gluing the Main Templates
Now you should have a stack of templates in order. Set the extra parts of the template aside (the flaps and alternate cover).
Start with the very left front part of the map. The part with the left half of the cover.
For the Templates With the Background
Fold along the pale edge where it says GLUE. Put a piece of scrap paper below the template and another piece of scrap paper above it, only letting the part that says GLUE be visible. This helps to not get glue on other parts of the template by mistake. Use your glue stick to apply glue. Line up the next piece and glue it down. Repeat this for the rest.
For Templates Without the Background
Line up the parts you are going to glue. Use a piece of scrap paper to mark your spot. Apply glue, line up again, and glue it down.
For Both (Important!)
When you get to the part of the template that has all the long lines across it, STOP. Do not apply glue to this one yet. We're going to be gluing it to another part later. At this point, just set aside what you've done and work on the next side, which will start with the right side of the front of the map.
Again, on this side when you get to the part with the long lines, STOP. Set this half of the map aside and now we can start on the middle.Use the same method we went over above to glue the remaining parts of the map together (besides the flaps and alternate cover, of course).
Step 5: Gluing and Folding the Flaps
You should have set aside templates for a large middle flap, an upside down L shaped flap, five smaller rectangular flaps, and the alternate cover. It's time to piece these together.
The Large Middle Flap
This part consists of three pieces. Basically just line these up and glue them the same way we did the main map. Make folds where the glue starts and then fold the end parts to that point so the flap can open and close. (Sorry for the poor explanation...) For reference, see the images and video.
The Upside Down L Flap
This part also consists of three pieces. Again, glue them together, fold where the glue starts and then fold the pieces back in on themselves. Use the images and video as reference.
The Five Small Rectangular Flaps
These don't require any gluing yet. You can fold these in half so that one side is the pale part that says GLUE and the other opens up.
The Alternate Cover
Fold along the pale edge that says GLUE. Nothing else needs to be done with this yet.
Step 6: Folding the Map and Gluing on the Ends
You should have three large parts of the map, which consists of a middle piece, a left piece, and a right piece.
Start with the middle piece. You are going to do an accordion fold all the way from one side, folding back and forth until you reach the middle. Then you will repeat this on the opposite side.
Now you can line up and glue the left and right portions of the map onto the bottom of the middle part that we just folded up. The trailing text should line up well on either side.
Now just do the same accordion style fold on the parts we just glued on until the map is all folded up.
Step 7: Gluing on the Flaps and Extras
We've hit the home stretch. All that's left is to glue on the flaps and reversible cover.
  • The upside down L flap glues on to a page on the left side of the map.
  • The large flap glues on to the very center of the map.
  • Harry Potter and Peter Pettigrew glue on to the middle part as well.
  • Dumbledore and Newt Scamander glue on to different pages on the right side of the map.
  • The Room of Requirement glues on to the left side of the map, on the page with the compass.
The reversible cover will glue on the the very ends of the map, extending the map a bit. They should be face down. Now you can fold them under to hide them or fold them over the top to reverse the cover into the message to Snape!
Step 8: Mischief Managed!
You're all done! Congratulations!
Let me know your thoughts and post your creations in the comments below!
If you liked this tutorial, feel free to share this tutorial and follow me on Instructables, YouTube, Facebook, Twitter, Instagram, and Pinterest!
Thanks for viewing!
7 People Made This Project!
  • Science of Cooking
    Science of Cooking
  • Pocket-Sized Contest
  • Trash to Treasure
    Trash to Treasure
7 Questions
Hi - I love this tutorial and can't wait to start piecing together my map, however, I'm having a problem printing the D and E sections (from 11x17 pdf) on A3 paper. My printer requires manual feed for A3 paper, but whatever way I flip the paper, the b-side is off-centre from the a-side. Any ideas? Thanks.
I didn't get the extra parts like the footprints and extra cover :( but the map looks amazing and can't wait to make it...just wish I had the extras :(
Nevermind, downloaded the A4 size and they were on that one XD (excited)
Hello, I wanted to ask what format of paper do you need if you want to print the full size map? Thank you :)
thank you very much for providing this awesome map for free.
I could only imagine how much time end effort went into this.
Made one as a birthday present for another Harry Potter obsessed fan. I printed the "No Background" version on A3 Paper and aged the Pages with black coffee and black tea. This gave the map a really nice finish. (I recommend glueing before aging, because the pages will crimp a little bit - i did it the other way round and it took me 4h until everything matched)
After that I used my botched Photoshop skills and added my own Footprints with a name tag to the map.
I am currently making a second map for my own, and started drawing additional Pages (2nd half of the 7th floor , Kitchen in the dungeons, ...). I'm currently using the Font "Wizard Hand". But as it turns out its a looooot of work to add even the slightest details.
Keep up the good Work and thank you!
i wanted to buy it for years but now i can make it my self thank youuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuu
Hi! Nice tutorial. I want to make the full size map, can you tell me the size of the paper you used? 'Cause I'm not printing it at home, I'm going somewhere else and want to make sure they print it right. Thank you.
Hi. Thank you so much for the tutorial. I'm going to attempt to make the map by printing in 8 1/2 x 11 paper. Once it's all put together, what is the actual size of the map when it's fully open?
Hi there! I want to print the Full Size version because I feel that would look best and would require the least amount of work. However, I don't know what paper size I need for the full size version (I know 11x17 is A3, and that you also have the A4 version). Could you please help me out?
I have downloaded the file but its not opening can you please help please !!!
I downloaded it on a Mac with no problem.
Make sure you have downloaded the entire file, it is rather large.
It should open no problem on Windows. I haven't tried it on Mac or Linux.
I must never really dumb, but do I glue a1 to a2, a2 to a3, etc? I’m so lost....
