Make beautiful marbleized paper in minutes.
Your finished paper can be used for any number of great projects!
Needed:
1 clean 5-gallon bucket filled with water
Sheets of paper; colored, construction, card stock, patterned...experiment with what you have on hand
Krylon spray paint, your choice of colors
Drying line with clothespins
Step 1: Go For It
Choose a clean, well-ventilated area and place a small drop cloth down on your working space.  Shake all of your paint cans thoroughly and have your paper, drying line, and clothespins ready.
Fill the bucket with water leaving a few inches at the top but deep enough to accommodate the length of your paper.
Select the color combination for your first piece of marbleized paper and spray a layer of color #1 onto the surface of the water within the bucket.  Spray color # 2, color #3 etc.  Be generous, the surface should be covered with paint.
The paint will float and mix on the surface of the water.
HINT: Don't wait too long before lowering your paper.
Hold your paper by the top edge either with clothespins or your fingers and dip slowly straight down into the center of the bucket.
The swirled paint will adhere as the paper is lowered
Pull your paper straight out and hang to dry.
NVDevastator says: May 30, 2013. 8:39 AM
Awesome, i would have never though of this. Good job!
doopidoop says: Dec 18, 2012. 11:34 PM
for paper you can also use normal old oil paints mixed with turpentine so they are like very liquid.
amnartist says: Aug 4, 2011. 4:28 PM
Nice instructable. I was going to submit a project with this same technique but on a cheap vase. Just ran out of time. I love using the faux marble look on artwork.
paleotool says: Jul 27, 2011. 5:29 PM
Fun and original! More please!
trowel_gal (author) in reply to paleotoolJul 28, 2011. 7:58 PM
The "More" is everything you can use the paper for after it is finished. Have fun!
PaleoPunk says: Jul 27, 2011. 5:08 PM
Wow! That paper looks so cool.
trowel_gal (author) in reply to PaleoPunkJul 28, 2011. 7:56 PM
Thank you! It is so quick and easy you can make a lot in a short time. Enjoy!
mr.squeakers says: Jul 27, 2011. 8:30 AM
Cool, im going to have to try this.
trowel_gal (author) in reply to mr.squeakersJul 28, 2011. 7:55 PM
Thanks mr. squeakers, I think you'll really have fun and every sheet is different!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
