Remove these ads by
Signing UpStep 1Parts and Tools
The speaker drivers ($12/each), back connectors, spikey feet, speaker wire, and poly stuffing were purchased online. All the rest locally sourced.
2 - 1.9L plastic fiber containers from big box store (regularity is good, ask Jamie Lee!)
2 - 3" magnetically shielded full range speakers(30 watts/8ohms) (speakers came with gaskets)
4- speaker connectors (2 black, 2 red)
8 - slip on connectors for the terminals
8 - pairs of fasteners to attach speakers to enclosures
4 - spikey feet
fiber filling
speaker wire
8 - #4 lead fishing weight eggs
duct tape
TOOLS:
Dremel Tool with router attachment OR Xacto knife for cutting driver opening
Drill with assortment of drill bits. You'll need a 3/8" bit for the spikey feet.
Small wrenches
Soldering iron and solder (if you break off a speaker terminal like I did)
Needle nose plier
Wire stripper
18" long thin hardwood dowel
Allen wrench
Permanent marker
Tape measure to calculate enclosure circumference and calculate 60 degree foot spacing
Ruler with mm scale
sandpaper & safety razor to smooth: cuts, sharp edges, and drill hole burrs
cello tape
http://www.madisound.com/catalog/product_info.php?manufacturers_id=136&products_id=1503
Good work. Just remember what I always say: a clean colon is a happy colon!
You're not going to get anything useful below 100Hz from a 3" driver in a 2L enclosure. Sorry, but that's physics. Although the author doesn't state what the drivers are, I'm guessing from the appearance and stated price that these are HiVi B3N drivers, which have a frequency response of 100-7000Hz and a resonant frequency (Fs) of 77Hz.
For anyone interested in making these, here's a URL for the driver...
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=297-428
I personally prefer Tangband drivers over HiVi. For anyone willing to consider an alternative, these drivers have more high end response and are somewhat more efficient, but don't look as cool and aren't shielded...
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=264-880
Small full-range drivers like this are pretty easy to burn out. Been there, done that. If you use an amp rated over 20 watts per channel, be careful.
