3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Mark I Super Psyllium Passivia Speakers
Step 2Mark and Cut Speaker Cutout, Drill Speaker Mounting Holes
This is by far the hardest step. The drivers require a 71mm circular cutout. Center the supplied gasket, tape in place, and mark the cutout with a permanent marker. The bottom plastic is tough. I don't like freehand cuts with a razor knife. My Dremel with router attachment cut a fairly decent hole. In order to accurately drill the speaker mounting holes, drop the speaker into the cutout, center and secure with tape, then drill through the speaker flange holes from the top into the container enclosure below. Just be careful and don't slip and damage the speaker cone or surround. The speaker is secured with hex head metric machine screws (#4/.70) with a pronged mounting nut installed backwards. When mounting the speaker later, a long hardwood dowel allows you to hold the nut in place while tightening the screw.
3 comments
Jul 23, 2009. 8:02 AMJCoffey says:
Are these Tang Band speakers? Do you ahve a link as to where you got them?
Mar 29, 2012. 5:19 PMiApple guy says:
You can also buy the same speakers at parts express!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:regularityaudiolabs
