Introduction: Marking Knife on the Cheap
I have been slowly getting into woodworking and decided I would start with a few small project to build my skill. So i looked in the normal places for projects and plans. I subscribe to Chris Schwarz webpage and often receive his emails about the things he is working on. One of his emails was about creating your own marking knife out of a drill bit.
I decided this seemed easy enough and was a pretty good skill builder. So with an old drill bit and some simple tools I set out to build a marking knife. A marking knife makes measuring and cutting wood cleaner and more accurate. So it will be a great addition to my growing inventory of tools. Enjoy
Step 1: Tools and Supplies
Tools:
Drill or Drill Press
Dremel and assorted accessories
Draw Knife
Sand Paper
Some sort of finish
Glue
Supplies:
Some sort of wood
A spade bit
Step 2: Pick Your Poison
I had a few old spade drill bits laying around so I had a few to choose from. Also some choices to make. Did I want to attempt a single bevel of a double bevel. I opted for the single out of ease and a smaller bit to start with.
Step 3: Cut the Bit and Shape
I decided on a single bevel and picked an angle at random to cut the bevel. To cut the bevel I used the cutting wheel on my Dremel tool. It wasn't to hard to get through the metal. I took my time to insure the metal did not get to hot. I was worried about effecting the blades ability to maintain a sharp edge. I then used the small sanding drum for my Dremel to sand the shard edge down. I also used a stone wheel on my Dremel at the end, but I didn't get a photo of that.
Step 4: The Handle
I had purchased, a long time ago, some blood wood pen blanks. I have a bunch of them, so i figured this would be a good handle to use.
I marked the top of the wood with an X. I just ran a straight edge from one corner to the other. Not perfect but it works.
Then I drilled a 9/32 hole into the wood. I went about 2 1/2" deep. I used a drill press, but honestly you could use a hand drill.
I then clamped the piece up in my bench mounted shave horse. Basically it is a horizontal vice.
**If there is any interest in the vise I will make an instructable on it.
Once clamped in place I used my draw knife to shave away material. I had not real plan, just started slicing away at it.
**A note about the draw knife- I got it at a flea market for dirt cheap. I paid like $5 for it or less. It had some nicks out of the blade, so i sharpened it up. It works like a dream. I love it.
I eventually got the desired shape and used the sanding drum on my Dremel to bevel the opening by the blade.
Step 5: Finishing the Knife
I decided to use an amber colored shellac for the finish and propped the piece up in a vice with a Styrofoam bowl to catch the run off (there wasn't any).
Once the finish hit the blood wood I was amazed at the color transformation. It turned out great.
I put two coats on it and fixed the blade inside with super glue. I was going to use epoxy, but didn't have any readily available and wasn't going to run to the store. It was a snug fit anyways.
Thanks for viewing the instructable. I hope you enjoyed it and it inspired you to design your own. I plan on making a couple more. I will most likely make the handle much thinner on the next one. I am open to suggestions and any comments.
Cheers.
The Vise used in the instructable.
Indestructibles Contest
UP! Contest
