Mark's Lego Candy Machine
2,214
8
5
Published
Introduction: Mark's Lego Candy Machine
This is my Lego candy machine. It has skittles and If you want to buy skittles. But, you have to pay 25 cents to have candy. You must put 25 cents in the coin machine to buy your candy. This candy machine has ramp for the candy to slide down and has a giant sign that says candy.
Step 1: Joining Plates Together
Take 3 thick Lego baseplates and join them together with 2 thin and long plates.
Step 2: Making the Candy Slide
Connect the two medium base plates together with a skinny base plate on the middle. Connect the mini holders to the large brick. Then, connect it to the base plate as shown.
Step 3: Adding to the Ramp
Add on flat pieces so the candy can slide down faster. Don't forget to put the thin rectangular pieces at the end.
Step 4: Adding the Walls
Build the walls as shown with nine levels. Then put holed rectangular bricks on top side.
Step 5: Finish Ramp
Add in a small wall that connects to the top end of the ramp.
Step 6: Add Roof
Add the roof by using two Lego base plates as shown in pictures.
Step 7: Add Candy Controls
Grab 2 long Lego sticks a round umbrella like brick, a holed brick and a stick piece to hold the Lego sticks together. You will need to push it so candy can come out.
Step 8: Build Candy Container Wall
Make sure you put that giant white piece at the back of the bottom so the candy won't escape. Put walls around the side so the candy wont come out. Add some translucent bricks to you can see the candy.
Step 9: Add Ceiling of Candy Container
Grab 3 giant white base plates and put them on top so no one will try to steal the candy.
Step 10: Create Money Fitter for Machine
This money fitter will make you be able to insert coins into the machine, Use the flat pieces, the small circular bricks, a flat square piece, a connect stud and a holed brick to make the money fitter.
Step 11: Finish Money Dispenser
build a wall around the base plate and put a door at the back to get your money.
Step 12: Add Supporter to Attach Money Case to Candy Machine
Grab two holed pieces, a base plate, two Lego bricks and 3 skinny circle Lego stabilizers to make the money machine connect to the candy machine.
Step 13: Add Candy Sign
Make a sign for candy machine by using flat Lego pieces and long flat skinny base plates.
Step 14: Adding Candy to the Machine
Buy some skittles and put them in the candy machine. Pull the lever at the back or front and the candy will spew out of the candy machine.
    • Casting Contest
      Casting Contest
    • Oil Contest
      Oil Contest
    • Make it Move Contest
    5 Comments
    I am so going to build this. marktomp, this is amazing
    Yes it does work like a candy machine
    Thank you, I worked really hard on my candy machine! :)
