Introduction: Marvels Avengers - Loki Costume
Picture of Marvels Avengers - Loki Costume
OK, So It took me 2 weeks to put this costume together in a big rush for a new zealand game/comic/video game expo called Armageddon
As I left this till the last second it caused a lot of stress, and my wallet wasnt very happy with me, but I hope you all appreciate it :D
Step 1: Drafting the Pattern
Picture of Drafting the Pattern
So the easiest way to make the pattern for this costume is to use a mannequin.
You may find that this is expensive, so, you should do what I did, make one by wrapping duct tape around your body sticky side up once, add 2 more layers sticky side down, then fill it with expanding foam once your done.  Only fill it bit by bit with the foam otherwise it well not set :D
To make your pattern, all thats done is a sheet of material is placed over the front and back quarters of the mannequin, from there you simply fold and trim the material back until it lines up where you want your seam allowances to meet.
A very important detail to make before removing your pattern is to add names/numbers and reference lines, this allows you to remember where and how panels go together, trust me, its very useful :D
Step 2: Transferring Your Pattern
Picture of Transferring Your Pattern
This part is really simple, All you are going to do is trace your pattern onto your material, and add a 15mm seam allowance wherever there is going to be a seam on your costume.
Once you have marked out all your pieces (making sure it all fits on the material) Cut out your pieces with seam allowance and reference markings marked on the inside of the fabric with dress making chalk.
Make sure to add the seam allowance, and then double check again, because without it, your not gonna have a good time.
Once you've cut out your panels, your going to have to do the same thing again with your lining, making sure that it is a reflection of your original panels if you are using anything other than a plan double sided liner.
Step 3: Making Sleeves
Picture of Making Sleeves
Ok, to be honest, sleeves will usually be a pain, so I recommend you do as I did.
Get your sleeve pattern piece thats drafted to fit your inside tunic, Then simply draw desired pattern, cut up, add seam allowances, and then cut appropriate pattern pieces (make sure to think about how your going to assemble it all)
Step 4: Gauntlets and Chest Pieces
Picture of Gauntlets and Chest Pieces
So these bits are really quite fun, you can use a variety of ways to make them, Including...
Making your core shape from foam, then covering it in builders bog.
Making one out of foam, then covering the front of it in plaster paris, removing the foam, and filling the mold with builders bog.
Or, simply making it out of foam.
The photos should make it fairly obvious how I mean.
After you have made your basic shape, you can use pva glue, wood filler pens, raising ink, or whatever you want to add your detailing to your piece.
Step 5: Trim and Panels for Robes
Picture of Trim and Panels for Robes
These bits of the costume are very minor, but somewhat important for detail.
The bigger panels on the waist are simply made from perspex, you can cut these to whatever shape you want, however, the easiest way of doing this is to take some card, cut it to the size of the panel you will be covering draw the shapes you want to be displayed, then cut up card.
The card pieces will be used to as stencils for your perspex plastic panels, from there you can sand, cut shape the panels however you want.
I cut out my panels, tapered the edges. spray painted them all metallic gold, and distressed them with a little bit of black paint.
When distressing anything, you want to put paint on the brush, then rub it off until there is almost no paint on it, then rub the material that you want to make look warn, if you still do this with too much paint then you can use a tissue to wipe it off and start again, lastly give it a coat of clear coat spray to stop the paint from rubbing off :D
Now, the trim.
This part sucks more than any other part of the costume, I took golden sheet metal from a craft shop I live near, and cut them into little 5mmx11mm rectangles, from there, folded them in half around a small rod, dabbed the inside with super glue, and then crimped them to the edge of the cloak. Its as simple as that, it just takes forever.Gold sheet
Step 6: Shoulder Pads
Picture of Shoulder Pads
This bit was a bit of a cheat technique, but very few people noticed :D
This bit involves you having to make a cardboard template, fitting it to your mannequin to look good. then cutting it from a rubber door mat :D Thats really it :D
To stick it to your costume you can do many ways, but I found that getting shoe repair contact adhesive was the best technique. The adhesive sticks to rubber, vinyl, leather, and pretty much everything, which makes it suitable for this costume :D
Step 7: Shoulder Plate and Strapping
Picture of Shoulder Plate and Strapping
This part is very similar to the gauntlets and strap piece, However, instead of making it out of bog, I kept it as foam to keep it light weight as its only one shoulder.
Once you have made your shoulder armor to the size and shape you want, you can heat gun the edges to shape and curl them a bit more, then give it 2 coats of pva glue with a brush, then a third watered down layer to eliminate brush stroke marks.  Add detail like the gauntlets, then paint and distress as much as you feel that it requires.
A buckle is required for this piece, I did not have one that was the right size so I simple cut one from a piece of aluminum using my rotary dremel :D
 The next bit just involves you having to make the adequate strapping to fit to your body size. :D
Step 8: Ok. Now Some of You Are Gonna Find This But the Toughest.... the Scepter.
Picture of Ok. Now Some of You Are Gonna Find This But the Toughest.... the Scepter.
For this build you will need:
Rotary Dremel Kit
Detail Sander (you can use general sand paper, this just makes things a lot faster)
Craft/box cutting knife
Basic Sculpting tools
Oscillating multitool
Heat Gun
Hot Glue Gun
Materials.
Builders Bog
EVA foam
Liquid latex or casting silicon
Clear Casting resin
Blue Food coloring or dye
Wood......
Cardboard
Expanding Foam
Plaster Of Paris or casting plaster
Perspex Plastic...
First thing is first, you have to decide what size you want to make your scepter, You can make your scepter to whatever size, just as long as its the right size for you.  If you make your scepter to big or two small, it will be very obvious very quickly.
For this step, I took a simple image that you can find on the net, Placed it into a drawing program, and added a box grid.  Once you have a grid, you are able to free hand draw this onto a piece of cardboard to use later.
Step 9: Scepter Pt 2 Body
Picture of Scepter Pt 2 Body
There are many ways of making your 2D image into 3D.
The scepter template was covered on both sides with "builders expanding foam", from there, a hacksaw blade was used to cut away the excess foam around the edge of the template.
From there you simply need to sand, and shape your foam to the shape you want your finished product to be.
Step 10: Scepter Pt 3 - Blades and Base
Picture of Scepter Pt 3 - Blades and Base
The blades of my scepter were constructed from pannels of perspex, you could use wood, perspex, aluminum, steel, whatever you like, just make sure that if you are going to use it for costuming, that you make it safe, noone wants to lose an eye.
How you produce this is completely up to you, for myself it was a mixture of using a rotary dremel, a miniature hand saw, and contact adhesive to build up multiple layers of perspex plastic to get the desired shape and thickness.
Step 11: Scepter Pt4 - Giving Your Foam a Shell
Picture of Scepter Pt4 - Giving Your Foam a Shell
Builders bog is a very popularly used costume/prop makers material, It takes 2 parts, the bog, and the hardner.
Usually for every golfball sized bit of bog you use, you would squeeze a 25mm line of hardner from the tube to mix with the bog.
What you are going to do here is basically cover your entire foam sculpt of your staff in bog, a really easy way of doing this is to wear latex gloves and use your hands, If you dont have gloves, then usually covering your hands in canola oil will do the trick to stop it sticking.
Make sure that you give your model atleast a 3mm thick coat all the way around 'minimal', Ideally if you can make it 4 or 5mm then you will have a stronger finished product after sanding.   The cleaner you can put this bog on, the easier detailing will become.
Note, in my picture I did the bog on foam in 2 separate halves, wouldn't recommend that way.
Step 12: Scepter Pt 7 - Making the Staff
Picture of Scepter Pt 7 - Making the Staff
This bit is really just up to personal style, I made my staff pole to about 70% accuracy for this.
I simply took a reasonable bit of wood, Cut a slight fat ended ' S ' shape into it with my oscillating multitool.
From there I filleted the edges to give it some curb, And then just sanded it down to give it that rounded smooth shape.
The base of the staff has to be a bit fat to make the staff look balanced, I did this simply buy gluing layers of EVA foam (camping foam mattress) to the base in a fashionable style.  Once you are happy with your foam you simple cover it in builders bog.
Lastly you will have to cut a box shape out of the top of your staff, the reason for this? Your staff will go inside the body of the staff head, and this is where you will place your battery pack.
Step 13: Scepter Pt 8 - the Orb
Picture of Scepter Pt 8 - the Orb
Ok, so this parts up to personal style, you can buy glass orbs, crystals, whatever you want for this bit. I personally used whats known as "clear cast resin".  It is a resin and a hardener kit that when combined correctly make a clear transparent material.
To make the right shape, I used Plasticine, made the desired shape, sprayed it with canola spray, then coated it in a few layers of liquid latex.    The liquid latex is to make a mold for casting the resin.
Once you have made a mold about 4mm thick, you then need to make a 2 part mother mold to make sure it doesnt stretch when you do your casting, I used plaster of paris as this does not to be a fancy casting.
Simply make a border around your latex where the plaster will be cast, layer your plaster, remove Plasticine, and with a piece of gladwrap on the other half, cast your other half of plaster (the gladwrap stops the plaster from sticking to itself).
Now simply open up your plaster mold, remove Plasticine from latex, fit latex back into plaster, and BAM, your ready to pour.
The Clear cast resin is something that is usually very particular about mixing quantities, so make sure regardless of which brand you get that you read the instructions.
Once mixed, by simply adding blue craft dye or food colouring you can color your cast, I used about 5 drops of blue food coloring for mine.
Step 14: Scepter Pt 9 - Staff Final Details and Fitting It All Together
Picture of Scepter Pt 9 - Staff Final Details and Fitting It All Together
Step 15: Scepter Paint
Picture of Scepter Paint
The paint part of this was simple, I coated the entire thing (except the orb) in metallic gold spray paint, then with some masking tape help, sprayed the bladed areas in metallic silver, then distressed it with black acrylic paint, just like with the armor, befor giving it a spray of plastic clear coat for protection
Step 16: Finished Product.
Picture of Finished Product.
Then if all has gone well, and you have followed these steps, you should have a well fitting, pretty accurate looking loki costume, the main key is to be patient, I had to rush this in 2 weeks of sewing, not fun :D
teamjelsa5 (author)2017-07-18
hey are you the guy who does those loki cosplays on deviantart???
Thunderb1rd (author)2016-10-03
Thank you so much!!! This tutorial is literally saving my Halloween costume.
LokisQueen (author)2016-04-17
I plan to make this for Halloween this year, but I was wondering if you could tell me about how many yards of each type of fabric you used? Thanks for the epic tutorial!
AthenasOwl299 (author)2016-04-05
I really love everything about this costume! Currently I'm making a lady Loki costume for myself to use at pax east in a couple of weeks. I'm wondering how did you applied the LED light to the resin mold? Or did you just set the light underneath it and it reflect it from beneath because it's clear resin after all? Also, how tall are you and how large were the grid patern for the blades. I just want to find the right proportion for myself and you really nailed it. Can't wait to hear from you! I've been literally studying your instruct able for months now and I'm finally making it!
AlishaPorem (author)2016-02-04
Hi,
I was just wondering how many rolls of duct tape & what type of
expanding foam you used for your mannequin? Also how did you get out of
it???
I'm about to start making a Captain America cosplay for this
years SupaNova & it would be so much easier if I had a mannequin
that's in my size rather than using my sisters old small store bought
one & trying to pad it out with pillows again!
I imagine it'd be useful in shaping out my boot-covers & gauntlets too.
corri.v.a (author)2015-03-23
What fabric did you use for the costume?
Dragonicz (author)corri.v.a2015-05-17
Almost forgot the, for the green green parts I used quilting fabric
hope you don't mind my input.
Hi there! When I made mine I used black vinyl for mine it's a lot cheaper than leather xp
DanniRose (author)2015-01-27
Wow. The costume is amazing!! What kind of fabric did you use?
Dragonicz (author)DanniRose2015-05-17
For the green bit, I used quilting fabric.
Dragonicz made it! (author)2015-04-09
Thanks for your help!!
Took me about a year to gather the free time t do it though lol xD
r2d2grrl (author)2013-08-07
I was wondering about what kind of fabric you used for this, as I'm working on my own Loki costume and getting the right look for the fabric seems to be my biggest issue at the moment. Also, since you mentioned it a couple of times, what exactly is bog? I'm interested in trying to make my own armor now, since yours came out beautifully--esp considering you said you put it together in such a short period of time. :)
CassandraM1 (author)r2d2grrl2015-02-14
I know you posted this comment a year go and probably won't be of any aid to you at all, but for mine--which you could find on DeviantArt here if you like http://alycia-of-kelowa.deviantart.com/art/Loki-Thinking-512691126 -- I used a stretch vinyl and green broadcloth. The beautiful thing about black stretch vinyl is that it look, feels, and even sounds like leather. It's a beautiful thing and not nearly as expensive or hard to work with. I hope this will help you in some small way. Good luck on your cosplay!
absolutely amazing. loved it, will have to put some time into making my own. thank you for making this instructable. if you don't mind could you possibly make another one showing how you made the Manikin. it was alittle hard to see how you made the one you have.
I made a Loki cosplay similar to this one, and for my mannequin I used duck tape and plastic baking wrap. I had my mother help me and she wrapped me up in the plastic and then on top of that wrapped me in duck tape. She cut a straight line up the back so I could get out of it and then I taped it back together, filled it with pillow filling, and stuck it on a stool. It's quite a nifty thing to have, especially if you plan on making a lot of custom fitted things. Good luck!
Rebecca-47 (author)2014-11-19
Oh! Also, have you ever made his helmet?
Here's a new challenge for you! A loki costume...on a budget! Aaagh!
I really wish I could make something quality like this, but even step one is too much for me... Making a mannequin of yourself? It seems crazy.
I wish cosplayers would sell their pro patterns. ^^' Because this sure isn't in the Simplicity catalogue!
WeaselyWheezers (author)2014-11-02
Whelp looks like I'm going to be attempting something that's going to end in tears :D
Anyway, I was wondering what material you used for the black parts?
Hey, I really love this! It's so well created and perfect!! I'm going to make this for DragonCon this year, and I was wondering what material you used for the green and black tunic and sleeves part of the costume? Thank you so much, this is fantastic!!
~ThatGuyWhoHatesSteveCarlsberg
lspringer3 (author)2014-02-12
I am looking for help my daughter wants to be Loki yes I said loki for comic con in august I'm do not know how to make this never learned to sow do you know people out there who could make this costume I am willing to pay for it to be made and for the material could you please help me find someone
Darthcooperp (author)2014-01-09
How long did it take?
CrystalB01 (author)2014-01-06
u do look like tom hiddleston
Jane Oreo (author)2014-01-03
i love this.
EarthboundEmpire (author)2013-12-15
How did you glue the chest piece to your shirt?
kkat567 (author)2013-11-09
Soooooooooooo amazing Loki is my favorite character
JackDF (author)2013-10-08
your kyle of asgard, friends of dafrontlinetrooper?
KyleofAsgard (author)JackDF2013-10-19
Indeed I am :D
darbie2728 (author)2013-10-10
:'3 <3 marry me omfg.
schmelkie (author)2013-10-08
oh my goodness! i am so in love with this. im going to have to try this so i can cosplay as him. thank you so much for this!
DoctorHarryEmrysWatson (author)2013-06-09
Thank you for answering my question thund3rcock! It's a great help! Hope to see more from you soon!
~DoctorHarryEmrysWatsonxxx
(P.S - my friend and I also love the glowing eyes, going to have to give that one a try some day!)
DoctorHarryEmrysWatson (author)2013-05-27
Hello!
I love the detail and effort that you put into this costume! Especially in two weeks!
I was just wondering though - because I don't recall reading this in your article - can you please tell me how much this costs to me?
-DoctorHarryEmrysWatson
Hey :D
Thank you very much. :D In total it cost me just over $400 bucks :D
mimisikokryptonite (author)2012-11-22
Ok, so you are awesome, just gonna say. But, if I may, did you make the "tunic" seperate from the coat, or did you sew them together? And how did you wire the staff?
poofrabbit (author)2012-11-13
Congratulations on being a finalist in the Halloween contest!!! Can’t wait to see if you win! Good luck!
The Rambler (author)2012-11-05
Too cool. I've been eyeing his shoulder plate for a while. I might have to copy you on that.
Honus (author)2012-11-04
Awesome Loki costume. You make a very convincing Loki!
Edwardo Leon (author)2012-11-04
my salute to your attention to details.. absolutely stunning .. you from downunder land?
Pixie Puddle (author)2012-11-02
that is an awesome costume, :)
Penolopy Bulnick (author)2012-11-02
Sweet, sweet costume!
About This Instructable
236,585views
347favorites
License:
More by KyleofAsgard:Witcher Cosplay - Geralt of RiviaReal Life Glowing eyes Effect(NO PHOTOSHOPPING)REAL LIFE GLOWING EYES!!!
Add instructable to:
