Step 4Sewn Face-Mask
Once you gather the right colors you just need to cut them in the shapes you want, layer them in the correct order and sew them on to the mask. If you are working with felt-like material you might even be able to use a hot glue gun, which would be especially useful for detailed areas like teeth. **If you use glue make sure it is clear colored and try it out on some of the scraps to make sure it holds before using it on your mask!
Example Shark Face-mask:
For the shark's face I cut the t-shirt into two strips that matched the length of my face-mask, then I cut jagged little notches along the length of one side of each of the two strips. Then I pinned the teeth onto the black face-mask.
Next I cut a piece of grey material to match the shape of the entire face-mask, adding a 1/4 inch extra space along the edges. I cut this piece in half to form the upper and lower jaws and placed the grey material over the mask. As I removed the pins holding the teeth in place, I folded and pinned the grey material along the edges and around the teeth, making sure plenty of the teeth were showing. Sew along all of the edges and your mask is complete!
Add Comment
