After living for close to two years without enough live/work light I decided to make a lighting fixture. One that would meet my specific needs without costing an arm and a leg. I had long thought of putting light bulbs in the hundreds of peanut butter and applesauce jars that I had eaten my way through. I had also collected my fair share of mason jars and thought that they too could make for an inexpensive solution. In the end I chose the mason jars as they don't come with sticky and hard to remove manufactures' labels and I wouldn't have to wait until I ate my way through ten jars of Crazy Richard's chunky peanut butter.
Before I went about an actual design, I searched the web to see if anyone had built a chandelier made from mason jars or similar. I came across several do-it-your-selfers. The best was posted by Our Hiding Place which led me to Pottery Barn's Exeter 16 Jar Pendant Chandelier. It's a really nice design and lists for $399. I was determined to customize mine and make it for less but I wanted detailed step-by-step instructions and I wasn't finding them anywhere.
First thing I did was to determine how much light I needed and what the electrical requirements would be. (Disclosure: I am not an electrician and am not recommending voltage or wiring. Each State has their own codes regarding home wiring. Also, the following instructions will not guide you on how to wire the ceiling leads and wall switch.)
The space where I planned on having the chandelier is over my dining/art table. (I built the table to again, suit my particular needs.) There is an existing electrical port in the ceiling that unfortunately, due to inept design is positioned too close to one wall restricting the width of a ceiling fixture. After identifying the maximum voltage I could then decide on the number of jars and matching bulb wattage. (Voltage, watts and amps are different. Again, I am not an electrician but am lucky enough to have a friend who is one hell of an incredible licensed electrician. If you don't know what you're doing, consult a licensed electrician.)
Based on my space and lighting needs, I decided on 10 jars with 25 watt bulbs. (Before you decide on the jars and the bulbs make sure the bulbs will fit inside the jars.) I tested different jars and bulbs first, before committing to the final design. I wanted to make sure that the heat generated from the bulbs wouldn't cause the jars to break or create condensation inside the jars. For the tests I purchased a simple lamp cord kit from the local hardware store. (It's a cord with a plug on one end and a socket on the other.) I already had a couple of mason jars on hand. My test proved successful so I ordered the rest of the needed parts. (See list on last Step or visit: http://brucekatlin.blogspot.com/ which includes links to vendors' sites.)
Step 1: Create Pilot Hole Template For Jar Lids
I decided to drill and wire the jars first, build the unit that would house the wiring after and then mount it to the ceiling. Being married to a hat designer helps with measurements. Together, we created a pilot hole template to drill through the lids of the jars where half of the metal nipple and wire passes through. I placed the paper pilot hole template on each lid and then screwed the outer piece of the locking lid on and marked the centered hole in preparation for drilling.
Step 2: Drill Lid Holes For Nipples, Attached Hex Nuts
Use a 1/4" metal drill bit to drill the holes in the lids and a 1/16" bit to drill 6 small holes around the lid to allow heat to escape from the jar. (I eyeballed the air holes, as no one would see them.) Next, insert the metal nipple through the hole leaving equal lengths on each side of the lid. Be careful, as the lids are very light gauge and razor sharp shards can cut fingers easily. I used a very fine metal sandpaper to remove the shards. Next, place a Hex nut on both sides of the lid and hand tighten before using a wrench to lock them into place.
Step 3: Measure Bottom of Ceiling Box For Drilling
Decide where you want the jars to hang from the bottom of the box that will be secured to the ceiling. Measure the center of the jars against the width and length of the 'junction' (ceiling) box so that the jars would be positioned proportionately. Drill holes large enough to accommodate lamp wire width, Holes will be drilled through the red circles in the below picture and the wires will go through them. The wires will ultimately be connected to the lead wires in the ceiling. (No, you're not crazy, I took the 2nd picture of the jars before I wired the keyless sockets.)
Step 4: Wire the Keyless Light Socket
With all of the lids drilled and the nipples locked down by the Hex nuts, it's time to wire the keyless sockets as pictured below. Make sure to pass one end of the wire through both parts of the lid, (Mason jars have air-tight lids by having two parts: one is the thin flat piece and the other is the screw-on cap) and then through the nipple. (We wanted the jars to hang 3' from the ceiling and cut the wire accordingly.) Before wiring to the two screws on the socket, you'll have to strip the wire covering with wire cutters. There is a positive and negative wire. It depends on the wire you choose as to which is which.
Step 5: Pass the Wires Through Both Parts of Lid
After the wire has been passed through both parts of the lid and the nipple, screw the keyless light socket onto the underside portion of the nipple. This is portion of the nipple that goes inside the jar. Screw the bulb into the keyless socket. At this point, your wiring and hardware should look like the picture below.
Each jar should now look like the second picture. Before attaching the other end of the wire to the ceiling wires, unscrew the lid and take the glass jar off. You don't want the extra weight at this point.
Step 6: Attach Electrical Grounding Bars
One of the best products ever invented is probably the Electric Grounding Bar. I used it to 'piggyback' all ten of the wires into two. The two wires will connect to the lead wires in the ceiling. The grounding bar is screwed into the junction (ceiling) box bottom as pictured below. I placed the bars close enough to the lamp cords but far enough away from each other as not to create a short. The corded lamp wire is poking through the pre-drilled holes. (Refer to Step 3 where you drilled the box bottom wire holes.) You will be bringing each of the ten lamp wires through the pre-drilled holes in the box's bottom.
Step 7: Split The Wires - Attach to Grounding Bar
Next, split the corded lamp wire so that the two wires are separated from each other, enough to reach each bar. Strip away 1/2" of the wire's insulation and insert into an open hole in the bar. Hand tighten using a Phillips screw driver the bar screws so that each wire is screwed to one side of the bar as pictured below. Using electrical tape, cover any exposed wire. (I used extra tape to ensure that non of the Rayon coded cord would be exposed.)
Step 8: Construct & Mount Ceiling Box
The most difficult part of this project was creating a box for the wires to be housed and that could be mounted to our concrete ceilings. I wanted to make this as simple as possible so I designed a topless box. You can make this any size you want. I wanted something as narrow as possible but deep enough to hold the wires and hardware. I cut a basic rectangle shape (see parts list below) using a 1" x 8" pine board for the bottom of the box and 1/2" x 2" poplar for the sides. I screwed the sides to the bottom using pre-drilled and countersunk holes and then screwed six 1/2" brackets to the inside portion of the box sides. The brackets were then screwed to the ceiling using a concrete drill bit and drill.
I am assuming that at this point you or someone else, (a licensed electrician perhaps?) has completed all of the appropriate wiring in the ceiling and on the wall switch. (I used a dimmer switch.) Have someone help you to lift the jars towards the ceiling as you place the box's bottom into place. Screw the box's bottom to the four sides, cover the holes and screws with wood putty and paint with color of your choice.
Step 9:
Now, screw the jars back onto their lids. If you measured correctly the jars should hang exactly where you wanted them. Turn the wall switch on and bathe in the light and satisfaction of a job well done.
Step 10: Parts List, Costs and Tools
1 case of Kerr Wide Mouth, 16 Ounce Mason Jars - $22.45
10 Keyless light-holder socket - $3.49 each
10 GE 25-Watt Crystal Clear G16.5 Globe Candelabra Base Incandescent Light Bulb (4-Pack) - $3.87
10 - 1/8 Nipples - .10 each. Pictured going through the lid of the jar and screwed into the keyless socket. The lighting wire will pass through them.
20 - 1/8-27 Zinc Hex Nuts .05 each. Used to secure the lid and the nipples together. Nuts and nipples where purchased from the great folks at Grand Brass who were extremely knowledgeable and helpful.
2 Electric 9 Terminal Ground Bar Kit - $5.22
Rayon or cotton covered lamp cord; 40 feet at $2 per foot. (You can find less expensive wire but I really like the old-timey look of the rayon or cotton covered wire. I purchased an extra 10' just "in case". You can find this at The Antique Lamp Company, eBay or Amazon.)
1 x 8 x 6 pine board - $16.45 (I cut mine to 29" for the bottom of the 'junction box'. The left over cut has been put to good use on another project.)
1/2 x 2 x 4 Poplar board for sides of junction box - $2.67
1 box of #9 x 1" Flat Head wood screws - $1.24
1/2" brackets - $2.77 each (You can get them much cheaper.)
Martha Stewart Black Coffee Metallic Glaze Specialty Finish - $5.48
Electrical tape - $2
Colored wood putty - $1.40
Tools:
Wire cutters
Phillips head screw driver
Electric drill and 1/4" bit
Hand saw
To see links to vendors' sites, go to: http://brucekatlin.blogspot.com/
You can purchase individual lamp cord kits. The ones that IKEA sells are very popular. You can either connect them to a power strip or cut the plug ends off, piggy-back them into one cord. The instructions that this designer used will help you: http://www.sproutingoff.com/?p=206
Good luck and let me know how it works out.
Cast about for a electrical product called a terminal block. Radio Shack probably has them, and many places on line. They come in sizes from one wire to dozens. They insulate the connections and cover some of them cover the connections to prevent accidental shocks.
They look as professional as bus bars, if not moreso. I do like that repurposed bus bars by the way, they certainly are handy.
Find nylon washer and bolts, if nothing else, to raise and insulate your bus bars. Available at hardware stores that have the whole aisle of nuts/bolts/fasteners/wingthingies.
That said, VERY nice looking. Nice proportions. Really well done.
Cheers,
Fin
Terminal blocks are used to connect 2 wires unless a jumper strip is used.
The lamp cord should have only enough insulation removed to expose approx.
1/4" of wire exposed. Electrical tape is only a band aid.
I do like the lamp.
Joe
Safety was my number one concern when building this project. (Electricity scares me). As I wrote in the introduction to the project, I consulted an electrician, as I am not one. Strehlow's comment is correct that, the wired socket pictured is incorrectly wired, (I would have replaced the photos if, I had taken them) I did wire all ten correctly as noted.
Regarding the bus bars being attached directly to the wood: the ceiling is 4' sealed concrete. There are no water sources above however, I agree that the bus bars be place "inside a plastic or metal box within the wooden one" or use Fin's suggestion of using nylon washers to raise the bus bar from off the wood.
Lastly, the screws that attached the sides of the wooden box are accessible, as I puttied them lightly enough for easy location.
Thank you to both Fin and Strehlow for their helpful comments.
Just a thought, but tinning the ends of the wire will keep it from fraying and give better electrical connections.
When placing the wires on the terminals in the sockets, always go around the screw clockwise. This is so the wire gets wrapped tighter as you tighten the screw. On yours, the wire is being pushed out from under the screw head as it is tightened.
Since the socket is hanging from the wire, it must have a strain relief. Typically this would be an "underwriter's knot." Another knot must be at the top. Do not rely on the electrical connections to be structural.
http://hope.edu/academic/engineering/labs/Electricity_Lab/Figures.html
Dropping a ground wire which is attached to the nipple to support the weight would be better. This is especially important as if one of the socket wires do pull off, the metal ring holding the jar in place could be energized.
Regarding the connections inside the box. The bus bars are fine for that but they cannot be attached directly to the wood. They must be on approved insulators. If water gets in there, the wood will become conductive and could start burning or be a shock hazard. And wood is not an approved electrical box. The connections should be inside a plastic or metal box within the wooden one.
A better solution would be to use crimp connectors to gather up all the wires down to a set of pigtails to connect to the in-wall wiring. That would probably be a bit cheaper than the grounding rails too.
The polarity must be maintained too. Yes, it is AC, but the two wires coming out of the box in the ceiling are not equal. The white one is grounded and the black or red is hot. The white wires must connect to the outside of the lamp sockets and the hot wire to the center terminal. This is so if someone changes a bulb with the power on, they don't get shocked touching the base of the bulb.
Finally, the box needs to be accessible. The screws cannot be puttied over. Any point where wires have connections must have an access point. So some other hanging approach would be preferred. A simple approach is to use another nipple protruding through the center that is attached to the ceiling with a flange, and then have a decorative cap nut to hold the box to the ceiling.
I was curious though: your ceiling looks like it's made of concrete, or perhaps panels of something. It goes very well with the chandelier but I was wondering what it was made of.
