Introduction: Mass Effect Crochet: Tali'Zorah
The pattern is similar to the Liara I made previously using the same head, torso, leg and arm patterns, only differing in the yarn colours; so if you made Liara this should be easy. I was thinking about giving her an omnitool as well, but didn't get around to it, perhaps I will add it later. I am thinking about making Femshep next if I have some time (and get some orange yarn for her hair) .
Step 1: What You Will Need
- Purple
- Yellow/gold
- White
- Grey
- Black
- 2.25mm crochet hook
- Yarn needles
- Polyfil/fibrefil stuffing of some sort
- Purple, pink, light pink, grey, and black felt
- Silver metallic pen and fabric for trim
- Glue
Rnd round
ch(s) chain stitch(s)
sc single crochet
sl st slip stitch
st(s) stitch(s)
sc2tog decrease by crocheting 2 stitches together
*About the yarn weight, the purple is definitely a 4, the other colours I picked up at a dollar store and they seem to be somewhere between a 3 and a 4 weight.
Step 2: Head (mask)
Starting with purple yarn (watch for yarn colour change in Rnd2 and 5)
Rnd1: Magic Circle 6
Rnd2: (switch to grey yarn) 2sc in sc 12st(s)
Rnd3: *2sc in sc, sc, repeat from * -18st(s)
Rnd4: *2sc in sc, sc, sc, repeat from * -24st(s)
Rnd5:(switch back to purple)*2sc in sc, sc, sc, sc repeat from * -30st(s)
Rnd6: *2sc in sc, sc, sc, sc, sc repeat from * -36st(s)
Rnd7-15: sc in sc, -36st(s)
Rnd16: *sc2tog, sc, sc, sc, sc repeat -30st(s)
Rnd17: *sc2tog, sc, sc, sc, repeat -24st(s)
Rnd18: *sc2tog, sc, sc, repeat -18st(s)
Rnd19: *sc2tog, sc, repeat -12st(s) Now is a good time to stuff.
Rnd20: sc2tog in rest
Fasten off. Leave tail.
Step 3: Head (mask Plates)
With grey yarn
Row1: 9ch(s), turn 8sts
Row2: sc in ch -8sts
Row3-11: sc in sc -8sts
Round plates (make 2)
With grey yarn
Row1: MC 6, ch1, turn -6sts
Row2: sc in sc, ch1, turn -6sts
Row3: 2sc in sc, ch1, turn -12sts
Row4: *2sc in sc, sc, repeat from *, ch1, turn -18sts
Row5: *2sc in sc, sc, sc, repeat from *, ch1, turn -24sts
Sew the grey plates to the sides of the head (mask). The straight plates should extend from the grey circle on the head and the semicircles should extend toward the front of the head. The scarf will cover part of the plates so the don't worry if it looks a bit odd right now.
Step 4: Torso
Starting with yellow yarn (watch for yarn colour change in Rnd6 and 7)
Rnd2: 2sc in sc -12st(s)
Rnd5: sc in sc -24st(s)
Rnd6: sc in sc (first 6sc with black yarn, next 17sc with yellow then last sc with black) -24st(s)
Rnd7: sc in sc (first 6sc with yellow yarn, rest with black) -24st(s)
Rnd8-12: (continue with black yarn) sc in sc -24st(s)
Rnd13: *2sc in sc, sc, sc, sc repeat from * -30st(s)
Rnd14: sc in sc, 30st(s)
Rnd15: *2sc in sc, sc, sc, sc, sc repeat from * -36st(s)
Rnd16-18: sc in sc, -36st(s)
Rnd19: *sc2tog, sc, sc, sc, sc repeat -30st(s)
Rnd20: *sc2tog, sc, sc, sc, repeat -24st(s)
Rnd21: *sc2tog, sc, sc, repeat -18st(s)
Rnd22: *sc2tog, sc, repeat -12st(s) Now is a good time to stuff.
Rnd23: sc2tog in rest
Step 5: Legs and Feet
Feet
With black yarn, make 2.
Rnd3: *2sc in sc, sc, repeat -18st(s)
Rnd4: *2sc in sc, sc, sc, repeat -24st(s)
Rnd5-6: sc in sc, -24st(s)
Rnd7: *sc2tog, sc, sc, repeat -18st(s)
Rnd8: *sc2tog, sc, repeat -12st(s) Stuff .
Rnd9: sc2tog in rest
Legs
Rnd1: Magic Circle 4
Rnd2: 2sc in sc -8st(s)
Rnd3: 2sc in first, sc, sc, sc, 2sc in next, sc, sc, sc -10st(s)
Rnd4-7: sc in sc -10st(s)
Rnd8-10: sc in sc -10st(s)
Rnd11: sc2tog in first, sc, sc, sc, sc2tog in next, sc, sc, sc -8st(s) Stuff.
Rnd12: sc2tog in each
Fasten off, Leave tail.
Sew the feet to the legs.
Step 6: Arms
Starting with black yarn, make 2 (watch for yarn colour change in Rnd6 ).
Rnd3-5: sc in sc -8st(s)
Switch to purple yarn
Rnd6-12: sc in sc, -8st(s)
Stuff it. Fasten off. Leave tail.
Sew the arms to the sides of the torso (black end at the top), they should be attached near the top in the yellow area. Sew the legs to the front so that the body is in a sitting position.
Step 7: Scarf Fabric
Once that was done, I cut the material in the shape below and covered the front edge with silver fabric trim as well as two stripes down the centre.
Step 8: Adding Scarf
Step 9: Other Embellishments
Step 10: Chatika Vas Paus
With white yarn
Rnd1: Magic circle 5
Rnd2: 2sc in first 4 sc , 3sc in last -11st(s)
Rnd3: 2sc, sc, sc , 2sc, sc, 2sc, sc, 2sc, sc, 2sc, sc -16st(s)
Rnd4: sc, sc, 2sc, sc, sc, sc, 2sc, sc, sc, sc, 2sc, sc, sc, sc, 2sc, sc -20 st(s)
Rnd5: sc in first 7 sc, 2sc, sc in next 9 sc, 2sc, sc in next 2 sc -22 st(s)
Rnd6: sc, sc, 2sc, sc in next 10 sc, 2sc, sc in last 8 sc -24 st(s)
Rnd7: sc in sc -24st(s)
Rnd8: sc in next 7, sc2tog, sc in next 10, sc2tog, sc in next 3 -20 st(s)
Rnd9: sc in next 3, sc2tog, sc in next 9 sc2tog, sc in next 6 -16 st(s)
Rnd10: sc, sc2tog, sc in next 3, sc2tog, sc in next 3, sc2tog, sc in next 3, sc2tog, sc in next 2 -11 st(s)
Rnd11: sc2tog, sc , sc2tog, sc , sc2tog, sc ,sc2tog, sc in next 2,sc2tog, sc -5 st(s)
Fasten off. Weave in ends.Cut pink and light pink felt pieces as in image 3 and glue them onto the white ball. If you want to incorporate an LED like I did with Glyph, you can find the instructions here.
