3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Master a perfect inline wire splice everytime
In this instructable i will teach you how to make a perfect inline wire splice, every time
What is an inline splice?
Well, if you work with any type of electrical wiring, and need to join 2 pieces of wire you have 2 choices, pigtail or inline
Pigtail splices are when you hold the 2 pieces of wire, one end going up, the other going down, and twist their stripped ends together.
The issue with pigtails are...
1) They are ugly
2) They redirect the wire 180 degrees, so going from point A to B requires a sharp bend
3) After making that sharp bend you have this chunk of pigtailed wire flopping about, usually with a nice wad of gooey black tape, and sometimes a zip tie to act as a strain control
4) Since the connection is 180 degrees (or going the totally opposite direction) without some form of strain control, all it takes is a stout yank to sheer the connection (even with solder), altho honestly this is an extreme con
The pro's of pigtail's are
1) they are "easy"
Inline splices is where you take two pieces of wire, and join them in a nearly seamless extension of wire
Inline the issues with inline splices are ...
1) the are "hard" (and I claim shenanigans!)
The pro's of inline splices are
1) They are almost invisible, and look professional
2) They do not redirect the wires natural flow, going from point A to point B is just as simple as if you had the chance to place a wire from point A to point B
3) Since there is no bends in the wire, there is no chunks to manage, which is especially handy in tight situations or where you do not have a lot of wire to waste (ie: repairing wires in a vehicle)
4) they are really strong, even without solder bonding them (keeping in mind that they are not permanent, stress and vibration will eventually disconnect them without solder)
Step 1Supplies
Something to splice
1 thumb and 1 finger per hand
Hemostats or needle nose pliers and maybe some gloves (see below)
Wire stripping utensil
Solder
Soldering Iron
Insulating material (heat shrink tubing recommended)
let me go off on a green note for a moment, my wire was scavenged from an old computer power supply, if you see anyone throwing away an old pc, snag it, its LOADED with wire thats good for jumper wires on your veroboard , or ribbon cable witch is also good for jumping, but since its tiny it works well with smd devices ect ...
your standard "still working but junk" power supply will net you a fiist full of wire, some voltage regulators, a heat sink, at least 1 good fan, a couple big caps, some other random electronic components, a handful of molex connectors for fans, or a nice +- 5v, +-12v and 3.3 volt bench power supply that can handle 10+ amps!
scrap the motherboard and you end up with MORE voltage regulators, connectors and swag, and if the case is at least ATX, well there you have a perfect platform for your pimping case mods, all for the cost of stopping the diptards at work from tossing that Pentium II thats been in the closet for over a decade, which equates to "hey let me have that!", as its headed to the dumpster
OK, about the hemostats and or needle nose pliers. you can do this technique with any gage wire, solid or stranded, but a brief word of warning!
even small gage solid core wire has a habit of screwing your hands up, ive had 24 gage stuff go deep into my thumb with little effort, and one time it went in to my thumb, to the side of my bone and thumbnail, and poke out the other end quite a bit (felt like a paper cut, until i pulled it out)
same with thick stranded wire, get some thick stranded wire and those strands become stray needles
if your working with these types of wire, pigtailed or inline, i recommend the use of metallic objects when you get to a point where twisting the wire
You should be able to start, and nearly finish the twist with your hands, but once it gets tough for your fingers, go for the tools, rather than a gash / piercing, and some nasty words spoken out loud around your loved ones
In this instructable I was using 20 gage stranded wire, which is quite soft, and wont poke my tough old work fingers at all
128 comments
1-40 of 128next »
Jul 28, 2010. 9:00 AMDeadlyDad says:
FYI, if you use heatshrink tubing that contains an adhesive, then using this method will yield a neat and waterproof join.
Sep 29, 2010. 9:48 AMCKOD says:
+1 to that, adhesive lined heatshrink is pretty much the best stuff ever.
Jul 27, 2010. 8:03 AMDannyboyINXS says:
I'm always using the "pigtail" connedction when wiring most things as it's easier to work with. I just overcome the "ugly" insulation by folding the connection over after soldering, and taping the connection to part of it's own length of wire. In fact, (seeing i hate working with heatshrink) i find taping "inline" connections more messy and prone to tape "sliding" along the wire and exposing the connection. It's just personal preference i guess, and when you're doing it all the time, you will develop your own quick method
Jul 27, 2010. 8:06 AMDannyboyINXS says:
Also, when soldering in line, or even in general, if you've got time, it does help to "tin" the ends and just solder them together rather than twisting them - as that degrades the integrity of the actual wire. It's good for proper professional connections - if you ever find yourself in such a situation.
Jul 26, 2010. 7:21 PMqwertyboy says:
Thank you so much for posting this. I was tired of all my connections coming apart easily and looking bad. With this method, the results look professional. In the photo, I had to add a LED inline with a fan to indicate when it was on. If I had tried to pigtail it, the results would have been bad. ~thanks~
Jul 26, 2010. 9:02 AMTANZMEISTER says:
Great information in the instructable! It might be helpful to add any notes about the soldering itself. Is soldering this splice any different then any other splice? A link that might be helpful to add, http://www.instructables.com/id/How-to-solder/ thanks for the great work!
Jul 26, 2010. 4:57 AMarcnemisis says:
Personally the improvements that this can make in a install or project far outweigh the time consuming part. Sure the pigtail/wire nut/soldered/twisted joint is easy, but it looks bad. I have been doing these joints (WU and just inline wrap RCA) for years while others wimped out. I try to spread the word and show them. Good job showing others how to do it right and make some projects cleaner and less tape gooeyness to go around.
Jul 26, 2010. 3:44 AMrfxcasey says:
Just wondering what is wrong with simple lap soldering? When don't right they are very strong and quick to produce.
Jul 26, 2010. 3:11 AMchndt2008 says:
good!
Jul 26, 2010. 12:11 AMrichardcole says:
nice trick and i think clean work is totally awesome... own heart satisfy when work to be done very well..
Jul 25, 2010. 7:14 PMrapidprototyping says:
My friends used have me wire thier amp because i never burnt one up simply because i insulated the wires and sldered where necessary these joints as i like call them twist up like a boobie lets call them wire joints western u8nion is so yesterday and RCA what have they done for me lately
Jul 25, 2010. 7:11 PMPyro667 says:
hey thanks for making me feel like an idiot, J/K...well a little, I much cleaner than my usual method Thanks
Jul 25, 2010. 6:42 PMurbanprimate says:
This is great! I've done my share of electrical repairs over the years, and I've ALWAYS pigtailed. This seems like simple, common sense but it's hard to let go of habits. I did this once purely because I didn't have a wire nut and remember thinking how much more sense it made, but once properly supplied I went right back to pt without even thinking about it! Beats the hell out of those cheap inline "bullet" style connectors especially!
Jul 25, 2010. 2:18 PMJon Chandler says:
This method of splicing has been around for many years, and is known as a Western Union splice.
http://wiki.answers.com/Q/What_is_a_western-union_splice
As for lap soldering....yes, it works. But as the experts say, solder is not designed to make a mechanical connection - only an electrical one. Wires should be mechanically secured before soldering. A lap solder joint should not be used for heavy duty connections or heavy-duty use.
Jul 25, 2010. 5:05 PMssnipe says:
From my experience: or you can use a "ENVIRONMENTAL BUTT SPLICE" its what we use in the aviation field works very well and weather proof might cost a bit more but a good investment. (quick google and might find a site like ...http://www.edmo.com/index.php?module=products&func=display&prod_id=18887 ... never bought or delt with them but its what im talking about)
Jun 23, 2010. 2:21 AMsabr686 says:
Nice,thanks. I didn't know there was a name for this method. I just instinctively used this method to save on wire and tape!
Sep 16, 2009. 7:12 PMsteviebob says:
Useful tutorial. Thanks.
Sep 6, 2009. 9:21 PMV-Man737 says:
So simple! Everyone needs to know this. Thank you for sharing!
Jun 28, 2009. 12:23 PMJunior_Electrician says:
I have been searching for days now, and came upon this in a google search. I am hoping you could help solve this issue: I'm trying to redesign my home stereo system so that I can mount my new speakers. My problem is that I don't have enough inputs, so I am splicing a few wires here and there to make what is basically a patch panel for all my stuff. Normally, this isnt a problem for me, but it became one when I went to splice some of my spare cables, and realized some of them had 2 wires inside, and some had three... And no matter which way I would join them to their own kinds, somewhere along the line I would need to join some 2-wire to some 3-wire... Anyone got advice on this? The 2-wire ones have the inner coated wire surrounded by the first wire, and the 3-wire ones are just 3 separately coated wires covered by the outer coat... Any help would be greatly appreciated!
Jun 28, 2009. 1:43 PMJunior_Electrician says:
**UPDATE**
Ok... I went and took a slight nap. After I woke up, I started a bit of testing with some of this. Its not like the spare cable wasn't replaceable...
Anyways, this is what I found out after some testing:
The 3 wires in the one cable were colored Red, Yellow, and Black. The other cables, and previously mentioned, were one wire coated and surrounded by the 2nd. I scrolled through google a bit more and saw that black was pretty much the same as the wire surrounding the first one in the 2-wire cable.
So I twisted red and yellow together, and twisted that pair to the single inner wire on the other cable.
That worked, and pretty well. The only down side is that it is mono by default. Thats not a big issue for me, seeing as im going to mostly use this "patch panel" for linking more speakers to different places easily. I am pretty sure most of the speakers I have are one channel each... ('Course, if they are multi-channel by whatever freak chance, that'd be cool =D )
Anyways. Now I guess the bigger question to ask would be if its possible to make it a stereo splice... I have several ideas, but they dont make complete sense...
If you have any info, please let me know. I hope this little bit of info helps someone else, too!
(If you want me to take some pictures with detailed instructions on any findings I make, including this one, feel free to contact me... Not like I got much of anything else to do for a few weeks...)
Mar 8, 2009. 7:37 PMsecaman says:
why dont you just lap joint solder them? all the twisting is not necesary
Mar 12, 2009. 3:33 PMdarkride says:
With lap soldering you have the chance of a cold solder joint since the wires are not physically tied together. I don't agree with the comment that a twisted joint has a higher resistance. Possibly yes if it's NOT soldered. As my old electronics instructor used to say, a good mechanical connect makes a good electrical connection. Lap connections are OK for a temporary joint, but I'd go with soldered twisted connections for something permanent. By all means don't twist wires together, wrap with tape, and run lamp wire under the carpet. I found exactly that in a hotel once. TWO sets of splices no less. And the manager couldn't car less about the complaint, nor did the corporate office. Wanna guess if I patronize that chain now? :-) By the way, those Scotch inline splices (the kind that you don't need to strip the wire) are not something you want to use in a car for anything under the hood, they WILL corrode and come back to haunt you!
May 15, 2009. 6:13 AMSolidSilver says:
Let me go all the way back to high school electrical practices class. When we were taught to do soldered 2 and 3-wire pigtails with solid 12-gauge, the instructor would then take two pairs of lineman's pliers and tear the joint apart. If there was not a clean copper-to-copper contact line, you failed. He explained that solder, being a combination of tin and lead, had inherently higher resistance than copper. Granted, these splices were intended for high voltage and high current, but I would say a soldered lap joint would have to be higher resistance than a twisted and soldered splice.
Mar 12, 2009. 8:30 AMCajunBorn says:
The lap joint solder is the way to go for an electronic signal wire. While the twisted inline solder is strong, it increases the resistance across the joint. The lap solder does not or at least has less of a resistance increase. Suprisingly, the lap solder joint will hold up under strain just as well as the twisted inline joint. Solder is that strong.
Mar 12, 2009. 7:27 AMwaterppk says:
I agree, solder is strongest in shear (lap joint). The twisting is unnecessary (although it does make the wires easier to hold together), but the biggest pain is that if for some reason you have to ever get it apart you won't be able to, once you get solder in that joint and it's twisted there's no way you're getting it apart short of two pairs of pliers and a soldering gun. If you're absolutely positively sure that for the rest of existence you want the wires stuck together, then twist them and solder :-)
Mar 8, 2009. 9:17 PMsecaman says:
you could use a solderless crimp connector. faster
Mar 16, 2009. 9:16 PMsnarke says:
I've found the crimp connecters work beautifully with stranded wire, and are useless crap with solid wire. I'd need some kind of hydraulic press (or a crimper with 2 foot long handles) to squeeze a crimp connector hard enough to compress it into solid copper wire. Naturally, most of the time I'm trying to join solid wires together.
Mar 12, 2009. 10:28 PMthinkdunson says:
i'm not sure what you mean about the proper crimpers. i've always used those long yellow handled crimpers that come with a solderless connector set. are those not a proper set of crimpers? they do perfectly fine for me, and all i use is the tip which basically just squeezes the connector flat over the wire.
Apr 24, 2009. 12:42 PMFeedTheGrid says:
Well done, osgeld. Thanks. FTG
Apr 17, 2009. 10:42 AMtudgeanator says:
This is so awsum. I, like many others have been using the pigtail method for sooooooooo long now, and i'm so glad to have found this way! Thanks so much. Oh, and good 'ible.
Apr 4, 2009. 1:34 PMizidor7 says:
You almoust got it wright, but almoust ,
and, this is a very nice instructable , respect man, almoust you got it eright.... but it dosen't metter because you solder them together... and the heatshrink makes it very nice to lock at.
Nice job!
Apr 10, 2009. 9:44 PMDarren. says:
you almoust spelt almost right.
Apr 10, 2009. 9:09 PMGorillazMiko says:
This method shows that you can make a solid connection without soldering, which is great for people that don't know how to solder, stuff like that.
Even though he did say to solder. But the connection is so good, you don't even have to solder!!
1-40 of 128next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
57
Author:osgeld
