Step 6Continue twisting
I recommend using your thumb and forefinger of each hand, 1 will go clockwise (or towards you) the other will go counter clockwise (or away from you), pinching hard, twisting only the spliced section, slowly moving towards the insulation with both hands
if your using solid core wire, or thick gage wire once you get near the ends I strongly recommend you wear gloves or use hemostats / needle nose pliers to finish up the twist
if you got close enough to the same length of stripped wire, and made your X close enough to the center of the 2 wires you should end up with both ends of the wire running out just at, or before the start of the insulation
And a super strong splice ready for service
Add Comment
