3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Master a perfect inline wire splice everytime
Step 7Wrapping up
Wrapping up
Solder the splice, but be warned once its soldered properly its quite a struggle to get it back apart, its actually easier to cut the splice out and start over, so make sure you have your heat shrink and whatever other accessories (ie parts to a fuse holder) in place before
Once you have done this a few times, it will become just as fast, as a simple pigtail
Your electronics enabled buddies will nod to you, and your other friends will be amazed at the clean nearly invisible splice, and how fast you managed to do it
Thanks for your time, and please if you have any questions or comments post them
-- Osgeld
16 comments
Jul 26, 2010. 9:02 AMTANZMEISTER says:
Great information in the instructable! It might be helpful to add any notes about the soldering itself. Is soldering this splice any different then any other splice? A link that might be helpful to add, http://www.instructables.com/id/How-to-solder/ thanks for the great work!
Jul 26, 2010. 4:57 AMarcnemisis says:
Personally the improvements that this can make in a install or project far outweigh the time consuming part. Sure the pigtail/wire nut/soldered/twisted joint is easy, but it looks bad. I have been doing these joints (WU and just inline wrap RCA) for years while others wimped out. I try to spread the word and show them. Good job showing others how to do it right and make some projects cleaner and less tape gooeyness to go around.
Jul 26, 2010. 3:44 AMrfxcasey says:
Just wondering what is wrong with simple lap soldering? When don't right they are very strong and quick to produce.
Jul 26, 2010. 3:11 AMchndt2008 says:
good!
Jul 26, 2010. 12:11 AMrichardcole says:
nice trick and i think clean work is totally awesome... own heart satisfy when work to be done very well..
Jul 25, 2010. 7:14 PMrapidprototyping says:
My friends used have me wire thier amp because i never burnt one up simply because i insulated the wires and sldered where necessary these joints as i like call them twist up like a boobie lets call them wire joints western u8nion is so yesterday and RCA what have they done for me lately
Jul 25, 2010. 7:11 PMPyro667 says:
hey thanks for making me feel like an idiot, J/K...well a little, I much cleaner than my usual method Thanks
Jul 25, 2010. 6:42 PMurbanprimate says:
This is great! I've done my share of electrical repairs over the years, and I've ALWAYS pigtailed. This seems like simple, common sense but it's hard to let go of habits. I did this once purely because I didn't have a wire nut and remember thinking how much more sense it made, but once properly supplied I went right back to pt without even thinking about it! Beats the hell out of those cheap inline "bullet" style connectors especially!
Jun 23, 2010. 2:21 AMsabr686 says:
Nice,thanks. I didn't know there was a name for this method. I just instinctively used this method to save on wire and tape!
Sep 16, 2009. 7:12 PMsteviebob says:
Useful tutorial. Thanks.
Mar 7, 2009. 10:59 PMidiotno1 says:
great tutorial. I learned something new. Thanks.
Mar 17, 2009. 7:34 AMFlash635 says:
I usually untwist the two bare ends and stuff them into eachother then twist them, solder them then apply shrink. It makes the shrinked join less lumpy
Mar 12, 2009. 12:04 PMJoeMutt says:
As a retired electrician, 40 years of service, we called this an RCA splice. This type of splice is not legal to use, in the United States, on normal household wiring (110/220 volt) as per the National Electrical Code. It can be used on low tension wiring (alarm system, electronic projects, door bell wiring, etc.).
Mar 12, 2009. 3:35 PMdarkride says:
The "official" name is a Western Union splice. They developed it in the old telegraph days since it was a good electrical and mechanic splice that held up well to the strain on the wires.
Mar 13, 2009. 10:31 PMfrollard says:
Yeah, western union is a cross with a tight (read: wraps touching another, like a hangman's noose) - this is just a really convenient twist :D
Mar 12, 2009. 2:56 PMYScuba says:
Cool. Very useful tutorial. (Now I've got to get some heat shrinkable insulation.)
Mar 12, 2009. 8:19 AMecafsub says:
wonderful!
I could have used this literally half an hour ago when I was splicing an alarm system leaf switch's wires back with the main ones coming out of the door frame. If only I'd checked my email first...
I'm not re-doing that work, but I'll certainly remember this from now on!
Embarrassing truth: I've been doing minor electrical/electronic work that requires this sort of job for *mrphgrmbldy* years, and I never knew about this technique.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
57
Author:osgeld
