Match Rocket
894
12
Posted in OutsideRockets
Introduction: Match Rocket
About: If homebuilt flight is your passion check this account out!!
This a very simple and effective rocket. This is the same thing from cube000. I thought it was so interesting that I had to do a instructable. Now I don't know the science. But the rockets just fly 5 feet but you can reuse the rockets and there about 50cents for all the materials.
Step 1: Making the Rocket+platform
First get materials(there all in the picture) then get a paper clip and bend it to the shape I made in the picture. Then get the match and cut off the end and get the flammable material. Now get a pointed stick and get a 2cmtimes6cm piece of aluminium foil and wrap it around the end of the stick. Now get the rocket out of the stick and put the flammable stuff in the rocket.
Step 2: 5-4-3-2-1 Llllllliiiiiifffffttttt Oooooofffffff
Now put the rocket on the end of the launch pad. Make sure there are no openings. Now get a lighter a light it at the bottom of the rocket. It will lift off and fly. Warning do outside away from objects and I will not be responsible for injurys.
    • Woodworking Contest
      Woodworking Contest
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    2 Comments
    I'm guessing that it would work something like a hot air balloon, the hot air is less dense so it rises. The quick blasts of hot air when the match heads ignite might do the trick. Otherwise It might have to do with the fire from the match heads sucking out all the oxygen and making it lighter than air.
