loading
Picture of Match Rockets
I'm taking a step back from the electronics and reliving my earlier years with an instructable on match rockets. I did not create these, i'm just sharing the idea. These provided hours of fun for me and my friends. Best of all, they are simple, and practically free to build. But as is obvious from the title, these use matches and are rockets, so they do deal in fire. Because of this, a precautionary statement is needed:
WARNING: Match rockets involve fire, and because of that, adult superviosion is required when young children are using the rockets. Always use common sense, and be safe when playing with fire. Always assemble and lauch the match rockets outdoors.
Step 1: Materials
Picture of Materials
With that out of the way, lets get to it. The first step is to obtain the materials. You will need:
Sheet of aluminum foil (Any size will do)
Box of kitcen matches (Large matches with the wooden sticks work the best)
Piece of wire (about 3 inches in length. You want something thin but rigid. A straightened paperclip works)
Scissors
Optional: Gas grill lighter
Step 2: Build the Launch Stand
Picture of Build the Launch Stand
First, bend the wire into a shape as shown. A wide, steady base is needed, and when place on the ground, a stright peice a little more than 1/4 inch long has to be pointed at about a 45 degree angle. This is going to be the launch stand.
Step 3: Prepare the Matches
Picture of Prepare the Matches
Using the scissors, cut the match head off as close to the lighting material as possible. Be careful not to chip the material off when doing this, since it is the match head we want. You can prepare multiple matches at once so you have plently of match heads availabe.
Step 4: Cut the Aluminum Foil
Picture of Cut the Aluminum Foil
This step isnt very critical. You want a peice about 3/4 inch by 3/4 inch, roughly square. But the exact demensions and size aren't very important.
tbell16231 year ago
I copied me
pcanywii1 year ago
That's awesome. I use lighters at my house but i don't know where to buy matches.?
this looks boss i have to make one of them i cant wate thnx
bayame1 year ago
can you make them bigger?
gemoney1 year ago
does it only work if u use tin foil could u use paper
iestrada22 years ago
I did this but I put tons if Match heads in on foil it didn't end well my eye still hurts
Nice Flame Picture.
JoeBeau (author)  blinkyblinky3 years ago
That was pure luck that it came out that well. It was actually a little breezy, and my camer kinda crappy with a very slow shutter (It was from when 5 megapixels was a LOT for a digital camera) The stars aligned for that photo
